d16a6 mini me timing belt help!
Old Oct 11, 2010 | 10:14 PM
hatchet_honda's Avatar
Default d16a6 mini me timing belt help!
i have a d16a6 with a z6 head. im on the timing belt part of the swap. i have the z6 belt but its too tight. and of course the a6 is too loose. right now its z6 belt/a6 tensioner/a6 water pump. im assuming the water pump has the same teeth regardless of vtec/non vtec blocks. ive seatched everywhere and got tons of diff scenarios. i tried the z1 tensioner and it doesnt fit on the block correctly
Old Oct 11, 2010 | 10:26 PM
macef9's Avatar
Default Re: d16a6 mini me timing belt help!
i would like to know too!!!
Old Oct 11, 2010 | 10:54 PM
coupatroopa's Avatar
Have you tried the z6 tensioner? I know everything that I read about the mini me swap, says to use the cam gear for the head, and get a adjustable cam gear. It also states that the cam will be one tooth off, and you can adjust that out with the cam gear.
Old Oct 11, 2010 | 11:04 PM
z6 tensioner is the same as the z1. which i have in the garage from my d15b vtec. doesnt fit on the a6 block correctly
Old Oct 13, 2010 | 08:32 PM
sooo i decided to use a z6 tensioner and modify the hole where it slides on the post attatched to the block. if i dremel the hold wider the tensioner will sit flat against the block and the belt should fit. i tried it with an old one from my d15b vtec
Old Oct 14, 2010 | 03:04 AM
singlecamsaint's Avatar
did you have any piston to valve clearance issuses with this i want to do the same thing and the only thing holding me back is that, i know the a6 pistons are domed (i think) and the z6 head is closed chamber, i just dont wanna bend up the valves
Old Oct 14, 2010 | 11:08 AM
jdm ef8 89's Avatar
I've been wondering the same thing for a while now to. I am also woried about piston to valve clearance. So since the a6 is too loose and the z6 is too tight would a d15b2 belt work or no?
thatseemslegit
42
Sep 17, 2015 09:07 PM
toolbox21
13
Jul 6, 2009 09:40 AM
92lxsleeper
May 24, 2009 08:20 PM
lazynok
Jul 30, 2004 10:11 PM
