stock p28 with a USDM gsr swap?
Old Oct 11, 2010 | 08:21 PM
bdassdrummr's Avatar
Default stock p28 with a USDM gsr swap?
will a stock p28 run ok with a gsr swap?? wondering if vtec will still pop and will the knock sensor go off
Old Oct 11, 2010 | 08:47 PM
acake em1's Avatar
Colonel Cake Mix
Default Re: stock p28 with a USDM gsr swap?
what vehicle is this going into?
Old Oct 11, 2010 | 09:10 PM
ricky00's Avatar
yes it will work.. it will eliminate the knock sensor and a few other sensors...but ur vtec will come on at 4500 and rev out at 7200rpm.. ur not gonna feel the full potential of the motor unless u chipped that ecu
Old Oct 11, 2010 | 09:29 PM
-__-'s Avatar
it will work but i wouldnt run your motor for a long time with the stock settings. chip it, or get a GSR P72 ECU.
Old Oct 12, 2010 | 01:21 AM
HondaPartsHero's Avatar
Technical Hero
chip the P28 with a GSR basemap
Old Oct 12, 2010 | 08:46 PM
its in a eg coupe. and i know the p72 is for the gsr would it run strong with that? like get the full power or is it better to just get the p28 chipped? i can get it done for $75 or trade for a p72. suggestions?
Old Oct 12, 2010 | 09:10 PM
NotAJDMFanBoy's Avatar
Either get the P28 chipped and tuned, or get a P72. The P28 can run it, and I know people who have done it, but it's not proper.
Old Oct 12, 2010 | 10:38 PM
20-EM2-05's Avatar
Either chip the P28 or find a P72.
Though, there's no point in chipping the ECU and running it on a GSR basemap if there's no mod done to it.
If you plan to run the stock P28 ECU on the GSR for a long time, say byebye sooner or later.
Old Oct 13, 2010 | 07:22 AM
the gsris modded has headers cams cam gears straight piping intake. what im trying to get at is would the p72 run better than a chipped p28? the p28 would basically just have a gsr basemap with no rev limit, vtec changeover point changed and 2 step.
Old Oct 13, 2010 | 11:00 AM
fungus mungus's Avatar
I've never been a big fan of chipped ECUs. With your setup, you really need to get an ECU that can be tuned on a dyno. A P72 with tuned on a Hondata would definitely run better than a chipped P28 with a generic basemap. If you take the car to get it tuned, you could tune it with a chipped P28, but it's a bit more cumbersome (burning chips takes more time than flashing a Hondata).
fm
worx
Jun 26, 2009 11:59 AM
singleslammer
Aug 19, 2006 04:49 PM
GDM93Si
12
May 9, 2006 01:58 PM
Jmunk
Jan 23, 2005 04:16 PM
u2civic1
Apr 1, 2003 09:54 AM
