91 integra starting problems
Old Oct 11, 2010 | 03:36 PM
chaggy's Avatar
Default 91 integra starting problems
So I swappaed out my trans and put a new clutch in. But now that car will not start. It clicks then nothing. What could this be?
Old Oct 11, 2010 | 04:24 PM
Speed Infliction's Avatar
Default Re: 91 integra starting problems
check your battery connections first. make sure the grounds are connected also. do you hear a lot of clicks or is it just one click?
Old Oct 11, 2010 | 04:27 PM
chaggy's Avatar
Just one click took the starter out and tested it and works good just I don't know about under a load.
Old Oct 11, 2010 | 04:33 PM
el crapitan's Avatar
check to see if you have 12v to the starter
how about the battery and grounds?
Old Oct 11, 2010 | 05:02 PM
chaggy's Avatar
Yeah it all looks good checked all the grounds and the battery and its all in working order. I'm just stumped on it
Old Oct 11, 2010 | 05:43 PM
integratt's Avatar
what about the ground for the thermostat, i remember i didnt connect that by accident and didnt start when connected again it started
Old Oct 11, 2010 | 06:13 PM
well it has to be a ground wire or your battery or the connection to the starter itself. you might have unplugged it when you took off the tranny. make sure it is plugged in all the way. then check for voltage on it.
Old Oct 12, 2010 | 09:10 AM
chaggy's Avatar
Well I got it going but its weird I think the starter was effed up some how because I threw my buddys in and it started right up. Wouldn't do anything with mine.
Thanks for you help everybody
J1MMY420
May 16, 2014 08:46 PM
memorybox
Jan 26, 2007 01:26 PM
sparxx
Jan 6, 2004 02:46 AM
liquid51
Jun 29, 2003 11:56 AM
See Are X
Mar 6, 2003 10:08 PM
