Adjustable shifter for 00 Civic??
Old Oct 11, 2010 | 01:05 PM
5.4ever's Avatar
Default Adjustable shifter for 00 Civic??
quick question guys. For a 2000 civic, is there such a thing as an adjustable shifter which lets you position the shifter wherever you want. im not talking about the actual shifting mechanism aka short shifter. What i want to do is be able to change the position of my **** close to the drivers side, but dual bend shifters do not really allow for adjustability. Something i can raise or lower, bend or rotate at my convinience. i know it sounds crazy but there has to be something like this out there
Also, can i just change the shifter without tapping into the gear box or do i need to mess with the whole linkage assembly regardless if it s just the top shifter part i want to change... thanks
Old Oct 11, 2010 | 03:54 PM
93egSLEEPER's Avatar
Default Re: Adjustable shifter for 00 Civic??
I know B&M makes adjustable shifter for drifting... Im not sure it its available for our model cars though. If you were to thread a piecd of pipe to fit the top of your shifter though you could make one yourself... Ive seen it done. Search around.
Just curious why do you want an adjustable shifter?
Old Oct 11, 2010 | 04:14 PM
grumblemarc's Avatar
The Grumpiest
There used to be back in the day. Matter of fact I think B&M made them.
Old Oct 11, 2010 | 04:18 PM
The Grumpiest
I lied. Pacesetter made them.
http://www.pacesetterexhaust.com/quikshift.htm
Old Oct 11, 2010 | 06:38 PM
5.4ever's Avatar
I just want to position it the best way possible. I feel that the **** is too far to the right for my way of driving. Im sure that maybe single of dual bend shifter may help but i was hoping that an adjustable existed so i wouldnt have to worry about not being satisfied about placement.
Originally Posted by grumblemarc
Thanks, that might be something id want
Also is there a "shifter" thread i can look for the positions these so called shifters give.
And lastly, will i have to do the entire process of switching out the linkage or is it just a bolt on? thanks
Old Oct 12, 2010 | 12:45 PM
5.4ever's Avatar
bump for a quick answer
Old Oct 12, 2010 | 01:08 PM
The shift lever bolts into the linkage. Its about a 45-1 hour job if your good with mechanics
Old Oct 12, 2010 | 02:08 PM
5.4ever's Avatar
damn, that what i was fearing LOL, thanks alot
JDM_rolex
Jan 1, 2014 07:16 PM
Boostn B20
Jul 12, 2011 07:35 PM
stehigs321
12
Oct 3, 2007 09:39 AM
EJ8 GSR-T
Dec 13, 2006 10:20 AM
gameknb
Jun 11, 2005 07:32 AM
