Asr rear subframe brace w/ type r 23mm sway install question!
Old Oct 11, 2010 | 11:19 AM
toolfan020's Avatar
Icon2 Asr rear subframe brace w/ type r 23mm sway install question!
Will I have any problems installing an ASR subframe brace/type r 23 mm sway bar on my 92 civic eg hatch with an Apexi WS2 exhaust already installed?
I have heard that people have run into problems with this sway bar setup not allowing for certain exhaust's to be installed? Does anyone here run this same setup? Any input would be greatly appreciated before I order these parts, thanks!
Old Oct 11, 2010 | 11:48 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Asr rear subframe brace w/ type r 23mm sway install question!
Not sure about on an EG, but if it helps, I'm running the ASR/ITR/WS2 on my EJ8 with no clearance problems.
Old Oct 11, 2010 | 12:25 PM
H22AFerio's Avatar
I kinda had a similar problem with a different exahust tho. but it was hitting the piping. I found out I had the sway bar installed upside down. so I flipped it 180 deg. and it didnt hit anymore.
Old Oct 11, 2010 | 12:27 PM
toolfan020's Avatar
Bump, thanks for the input, any fellow eg owners with this setup want to chime in? =P
Old Oct 11, 2010 | 01:16 PM
tlarimer's Avatar
I'm running a 22mm rear sway bar, asr subframe brace and 5Zigen 2.5" exhaust on my EH3 and even on 2.5" drop I never had any clearance issues.
Old Oct 11, 2010 | 03:50 PM
93egSLEEPER's Avatar
Im running the ASR subframe and sway bar combo (24mm) and had a slight touching problem on my WS2... I just bought a tighter/shorter exhaust hanger and it holds the exhaust tighter up to the underside of the car. Problem solved
Old Oct 11, 2010 | 05:01 PM
toolfan020's Avatar
Thanks for the input, I guess if it comes down to it I will just have to get a shorter hanger for the muffler.
Old Oct 11, 2010 | 05:11 PM
H22AFerio's Avatar
yeah you can get a set of polyurethane replacement hangers on http://www.horsepowerfreaks.com/sale...xhaust_Hangers keeps it from moving arround alot.
Old Oct 11, 2010 | 05:20 PM
toolfan020's Avatar
oh snap, nice! ty As it is now it doesn't move or rattle one bit, but then again I haven't installed the new sub frame brace and sway bar either hehe.
reysi1026
Jul 23, 2010 04:46 PM
djdownfawl
Honda Civic (2001 - 2005)
39
Dec 1, 2008 07:34 PM
thegreat0ne
Aug 24, 2007 09:29 PM
SaYjAiBaO
Oct 26, 2006 05:58 PM
litterbox
17
Mar 15, 2005 08:02 PM
