sway bar question
Old Aug 24, 2007 | 05:52 PM
thegreat0ne's Avatar
Default sway bar question
just installed a blox sway bar today. The ends of the sway bay have no bushings in them like the oems do. Do i need to buy that seperately? do i even need the bushings? second, I connected the bar to the oem end links and there was alot of space for the bar to move around so i put X amount of washers within the endlinks. is this safe?
Old Aug 24, 2007 | 09:29 PM
TastyDragon's Avatar
Default Re: sway bar question (thegreat0ne)
concerning your endlink, if im not mistaken tha blox rear sway is made for a type r right? tha type r has a thicker subframe where you mounted tha sway bar's D brackets so i think thats why you have extra space where you bolt your endlinks in. also i think if you're trying to run tha blox rear sway you should also have a subframe reinforcement kit. someone on here has a blox rear sway with asr subframe brace. im running a 98spec jdm itr rear sway with asr brace and tha endlinks go in perfectly with no extra space like what you're describing. can someone confirm this?
patrickstar
Mar 1, 2009 09:15 AM
grandtheftlunchbox
23
Nov 4, 2008 08:06 PM
Mikes2000civicsi
Mar 27, 2008 09:02 PM
DarkBB4
Feb 1, 2006 01:16 PM
