syncrowave 300?
Old Oct 11, 2010 | 08:12 AM
thegatekeeper14's Avatar
Default syncrowave 300?
so would this be more welder than whats actully gonna be needed for the most common welding that most you guys do.
Old Oct 12, 2010 | 10:08 AM
jdmadam's Avatar
Default Re: syncrowave 300?
thats a great welder. I highly recommend it
Old Oct 12, 2010 | 10:06 PM
91jdmhatchback's Avatar
well personally i can't see a need for more then 200 amps on a daily basis. I have had no problem welding very large intercoolers with my sync 200 so unless you will be welding very thick aluminum i can't see a reason to spend the extra money on a big welder.
Old Oct 13, 2010 | 06:28 AM
chrisbmx68's Avatar
I second not needing more than 200a unless you weld thick things a lot, or are going to stick with it.
I wouldnt even really consider a transformer machine nowendays unless you are going to hammer it and have a super high duty cycle in a production environment.
Look at the thermal arc 185 its a great machine at a good price point with a lot of features the syncrowaves dont have. Same goes for the dynasty 200dx and the lincoln invertec 205
Old Oct 16, 2010 | 08:26 PM
5.0 Killa's Avatar
I haven't outgrown my Syncrowave 200 and don't think I ever will. Even aluminum intakes aren't bad, my buddies older syncrowave 180 is probably even good enough for 95% of hobby stuff.
Old Oct 17, 2010 | 07:03 AM
9bells's Avatar
OG Fabricator
300 is fairly serious, and I can't imagine the power it takes to run it. My sync 200 was over 50 amps when maxed, which was a lot.
Old Oct 17, 2010 | 09:10 AM
dave@passenger's Avatar
Well if you ever want to weld anything over .25" thick in aluminum you will need all of that 300 amps.
Old Oct 17, 2010 | 09:56 AM
CRMB's Avatar
OG Fabricator
I would assume you are looking at an older / used 300 (as the 300s have long since been discontinued I believe) for a good deal which probably defeats the "need" versus "want" discussion. However, I think chris is correct and the deal breaker will be the power requirements. Our sync 350 prior to owning the dynasties was an insane power sucking monster. I can run 5 dynasties for the same power usage as that power pig, and if I remember correctly it was supposed to be more power efficient then older models.
Old Oct 17, 2010 | 07:35 PM
jdmadam's Avatar
I didnt read the thread topic correctly. I thought it said syncrowave 200.
Well I have the syncrowave 200 and I highly recommend that.
JDM EJ1 95
Welding / Fabrication
16
Nov 20, 2007 06:39 PM
SequenceGarage
Nov 1, 2006 09:36 AM
DIY_Racing
Feb 9, 2005 02:38 PM
Recluse03
Dec 19, 2004 12:16 PM
GTlvr82
Audio / Security / Video
23
Apr 4, 2003 03:13 PM
