Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 CRV will not crank
Old Oct 11, 2010 | 07:55 AM
crvx3's Avatar
Default 2000 CRV will not crank
Here's a crazy one.
Car was running fine. Decided to do some maintenance.
Replaced distributor cap and rotor.
After install car will not crank. Turns over fine. Will not fire.
Tested cap and rotor and ICM and Ignitor and all appear to be within spec.
Any suggestions?
Thanks
Old Oct 11, 2010 | 11:12 AM
flossie127's Avatar
Default Re: 2000 CRV will not crank
I suggest checking the rotor and the cap will do, check if its placed properly. goodluck on the install!
__________________
honda crv parts
Old Oct 11, 2010 | 11:58 AM
fast2camciv's Avatar
firing order correct?
2ndName
Jan 30, 2006 11:32 PM
ricemikecd5
Jun 14, 2004 03:23 PM
2lowintegra
May 6, 2003 12:40 PM
93SSPHatch
May 31, 2002 04:13 AM
93SSPHatch
May 30, 2002 02:55 PM
