ccivic hatch /crx
So do I use my original park cable ? And wich hose do you mean ? My original one or the one off the crx ? Would it be easier for me to dump the crx rear end and go with the integra rear end ?
You can't use your original parking cables because the ends are different. They attach to a caliper differently than they do to the disc. You need new brake hoses (flexible lines) for the same reason.
You can use the CRX trailing arms, just buy DA cables, either new or from the junkyard.
give him a break. can't expect people to know chassis codes if they've never heard them before.
op: if using crx rear disc trailing arms then you could use the crx si brake cables. da cables should be used with da trailing arms.
I have the whole trailing with the cable connected and break hose so ill replace that with tha da stuff right and then every thing else should be straight foward. Again thanks for the help
hatchblack
26
Jul 17, 2004 07:39 PM
