95 civic ex/gsr motor/auto to manual - starter won't crank engine
Old Oct 10, 2010 | 05:04 PM
Slowp0ke's Avatar
Default 95 civic ex/gsr motor/auto to manual - starter won't crank engine
ok well lets start off by saying this
the car is a 95 civic ex that was auto converted to manual and has a gsr motor and transmition street tuned on crome
ok i went away for a few days and took my auto gear select out of neutral for theift reasons ,... well when i get back i put it back in neutral and the car wont start...not even cranking... i put the key in and get the honda chimes.. but when i turn the key absolutely nothing happens no clicks .. battery is full charged i even took my chip out and put it back in and nothing... but when i go to use my 4 ways its giving off a loud squeal same with the fogs i tried playing wit the ecu the gear selector , and even tried jumping it and nothing... what could it be guys?
Old Oct 10, 2010 | 06:20 PM
rndmheroxx's Avatar
Default Re: my car wont start please give a hand
try turning the ignition on and supplying power to the starter directly and see what happens
Old Oct 10, 2010 | 07:28 PM
hillssol95's Avatar
agreed if theres no click the starter isnt even trying, make sure that its actually in neutral.
Old Oct 10, 2010 | 07:40 PM
eazy64's Avatar
could be ur clutch switch. follow the clutch pedal if u have one and there should be a button on the back push it then try starting it.
Old Oct 11, 2010 | 07:28 AM
Slowp0ke's Avatar
that switch isnt hooked up in the past i was able to start the car without pushing in the clutch though
Old Oct 11, 2010 | 07:29 AM
Slowp0ke's Avatar
i tried jumping the battery is this the same thing? if not could you go into specifics?
Old Oct 11, 2010 | 07:30 AM
Slowp0ke's Avatar
thats what im thinking ... i need to try to find another automatic gear selector.. i think it **** the bed on me... but if i can try other things i will
Old Oct 11, 2010 | 07:43 AM
SIM Racing's Avatar
Possible Ignition coil in your dizzy. they randomly go out from time to time. might be time for a new one.
Old Oct 11, 2010 | 07:53 AM
hillssol95's Avatar
wait i thought this was a manual, why do you have an auto gear selector?
Old Oct 11, 2010 | 11:22 AM
Slowp0ke's Avatar
it was automatic swapped to manual you HAVE to keep that gear selector in the car in the neutral position for the car to start
Old Oct 11, 2010 | 12:34 PM
Slowp0ke's Avatar
UPDATE!! ... I full charged the battery and now i get a signal click from the engine bay when i go to start it ... so i think it is a starter selinoid (spelling) easy fix ill swap it out tom. and il give another update ... thanks to all that is helping me solve this
Old Oct 11, 2010 | 01:28 PM
TwoFacedCustoms's Avatar
Good luck man...is there no other way when doing the manual swap to override that whole gear selector situation?
Old Oct 11, 2010 | 01:29 PM
Slowp0ke's Avatar
not that i know man
Old Oct 11, 2010 | 01:34 PM
Former User's Avatar
Default Re: 95 civic ex/gsr motor/auto to manual - starter won't crank engine
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Try wiring the starter directly to the battery. If it won't crank, the starter may be bad.
Old Oct 11, 2010 | 02:47 PM
Slowp0ke's Avatar
thanks ron! ill try that tom.
Old Oct 12, 2010 | 05:52 AM
del_sol_freak's Avatar
I did a auto to manual swap on my 94 civic and I have a jumper wire. That way I dont have to put the shifter back in the car. It makes it think that the car is in neutral. I will take a picture tonight and show you how if, you want me to. The car is not with me as i am doing a j swap to it.
Old Oct 12, 2010 | 09:20 AM
Slowp0ke's Avatar
yes please do man that whould be great!!
Old Oct 12, 2010 | 11:57 AM
Here is the write-up that i followed. The part about the wiring is at the bottom. Hope this helps to get rid of that shifter.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
Old Oct 13, 2010 | 08:54 AM
Slowp0ke's Avatar
update:
i put a new starter on and the problem is still there... i know its not the main relay cause my fuel pump is priming everytime... i tried a different battery also..im kinda stuck right now???
anyone?
Old Oct 13, 2010 | 09:36 AM
the_hatch_life's Avatar
check all your grounds had the same problem with a previous hatch. if all the grounds are connected scuff em up and reattach.
Old Oct 13, 2010 | 10:47 AM
rndmheroxx's Avatar
id check your ignition coil. mine went out on me too! if its bad at least its an easy fix! look at the diagram here for values you should look for.
http://www.clubcivic.com/board/showthread.php?t=180000
if that tests out good. the problem has GOT to be that auto gear select!! you said it was working fine before you took it out, and when you hooked it back up thats when it stopped cranking. my guess is your problem is there. Id take it completely out, and redo it, checking grounds and voltage supplys, idc if youve checked 50x already....we all miss something stupid sometimes, check for the 51st time lol
Old Oct 13, 2010 | 03:09 PM
Slowp0ke's Avatar
thanks guys i replaced all my grounds with new ones and the damn thing fired right up.... thanks for all your help guys!! im back on the road again YAHHH
Old Oct 13, 2010 | 04:31 PM
grant97teg's Avatar
So wait. Your telling me your driving around with a auto gear select just hanging there? Lmao. It's 4 wires, you wirem so you have two left. es
Old Oct 22, 2010 | 08:27 AM
Slowp0ke's Avatar
no its not just hanging there its tucked up under the dash
90blkteg
Jun 21, 2013 11:44 AM
ejvtec
Jun 16, 2011 05:21 PM
Hatchd Egg
Sep 8, 2009 08:59 PM
HondaIsBueno
10
Apr 14, 2008 08:14 PM
hybridpatient95
Apr 22, 2005 12:38 AM
