95 civic ex/gsr motor/auto to manual - starter won't crank engine
ok well lets start off by saying this
the car is a 95 civic ex that was auto converted to manual and has a gsr motor and transmition street tuned on crome
ok i went away for a few days and took my auto gear select out of neutral for theift reasons ,... well when i get back i put it back in neutral and the car wont start...not even cranking... i put the key in and get the honda chimes.. but when i turn the key absolutely nothing happens no clicks .. battery is full charged i even took my chip out and put it back in and nothing... but when i go to use my 4 ways its giving off a loud squeal same with the fogs i tried playing wit the ecu the gear selector , and even tried jumping it and nothing... what could it be guys?
Re: my car wont start please give a hand
UPDATE!! ... I full charged the battery and now i get a signal click from the engine bay when i go to start it ... so i think it is a starter selinoid (spelling) easy fix ill swap it out tom. and il give another update ... thanks to all that is helping me solve this
Re: 95 civic ex/gsr motor/auto to manual - starter won't crank engine
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Try wiring the starter directly to the battery. If it won't crank, the starter may be bad.
I did a auto to manual swap on my 94 civic and I have a jumper wire. That way I dont have to put the shifter back in the car. It makes it think that the car is in neutral. I will take a picture tonight and show you how if, you want me to. The car is not with me as i am doing a j swap to it.
Here is the write-up that i followed. The part about the wiring is at the bottom. Hope this helps to get rid of that shifter.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-my-auto-manual-swap-pics-56k-no-no-2090074/
update:
i put a new starter on and the problem is still there... i know its not the main relay cause my fuel pump is priming everytime... i tried a different battery also..im kinda stuck right now???
anyone?
anyone?
check all your grounds had the same problem with a previous hatch. if all the grounds are connected scuff em up and reattach.
id check your ignition coil. mine went out on me too! if its bad at least its an easy fix! look at the diagram here for values you should look for.
http://www.clubcivic.com/board/showthread.php?t=180000
if that tests out good. the problem has GOT to be that auto gear select!! you said it was working fine before you took it out, and when you hooked it back up thats when it stopped cranking. my guess is your problem is there. Id take it completely out, and redo it, checking grounds and voltage supplys, idc if youve checked 50x already....we all miss something stupid sometimes, check for the 51st time lol
thanks guys i replaced all my grounds with new ones and the damn thing fired right up.... thanks for all your help guys!! im back on the road again YAHHH
So wait. Your telling me your driving around with a auto gear select just hanging there? Lmao. It's 4 wires, you wirem so you have two left. es
Hatchd Egg
09-08-2009 08:59 PM
HondaIsBueno
10
04-14-2008 08:14 PM
hybridpatient95
04-22-2005 12:38 AM
