help me please, car pulling bad
so i recently replaced my driverside axle and my passenger side upper ball joint and aligned my car and now something else is seriously wrong with my car.
Driving my car (1990 DA) it will drive normal for a while and then out of nowhere it will pull really hard to the right, like hard enough to yank the steering wheel out of my hand if i'm not paying attention. this lasts for about 3 seconds at a time and then stops and the car will drive normal again. does anyone know what could be the problem with the car? at first i thought it might have been something wrong with the axle that i put it, but now i'm pretty sure its not because all sounds/ noises that happen are on the opposite side from me. any help would be much appreciated.
Other info:
1990 Integra GS
Lowered on sprint lowering springs
tociko blues
stock motor with intake
Other info:
1990 Integra GS
tociko blues
i checked everything out and nothing looks broken or abnormal. the only thing thats questionable at all is the right axle has a torn boot. could an axle cause this to happen?
also i realized that this happens more after the car has been driven for a while. when i first start it and drive it acts normal.
If the boot is torn, it means there is no grease in the CV joint which is very bad. Not only it affects your driving and screws up the axle completely, but could also kill your differential and you end up replacing the whole transmission.
Get that fixed ASAP
Get that fixed ASAP
so it was def the axle, i had the car parked but had to drive today to go to class, and on the way back my axle just snapped going around a turn. luckily everything seams to be okay, i replaced it and drove home. thanx for all the help tho guys
freezy
11
May 9, 2011 02:19 PM
zizux
Aug 28, 2003 01:11 PM
