Code 14 bucking at part throttle please help me
Old Oct 10, 2010 | 09:45 AM
jimmy o.'s Avatar
Default Code 14 bucking at part throttle please help me
Ok I'm getting really irritated my car is either a retard or I am things I've tried/checked
Tps is in spec
Coolant temp sensor is new
Throttle body is clean
Now I just tried a chipped pr4 with my basemap installed on it and my car revs to 2k rpms dunno why (it was a auto ecu if that matters it was chipped by phearble.net)now if I unplug my iacv the idle goes way down(still surges at part
throttle tho)when it is plugged in it won't do it cause it idles
higher than when it usally surges between 1,500-1,600 in
that area
Now my chipped p28 idles fine it just does the same thing
and throws the same stupid code....
Car is a 94 civic ex with a jdm B18C
Old Oct 10, 2010 | 09:54 AM
jimmy o.'s Avatar
Default Re: Code 14 bucking at part throttle please help me
And cleaned my iacv
Old Oct 10, 2010 | 10:26 AM
devney's Avatar
Maybe your IACV is just bad. Try another one.
Old Oct 10, 2010 | 10:36 AM
jimmy o.'s Avatar
For some reason I'm really paranoid about the wiring on this car (mainly due to how the fogs where wired) and a few of the wires by the ecu are reran or cut and spliced...
Also noticed a plug behind the intake hangin that looks just like the iacv plug hmmm
Old Oct 10, 2010 | 12:41 PM
jimmy o.'s Avatar
Well the plug is right but why would it idle high with one ecu and not the other?
And it dosent idle higher when cold like normal it'll idle like normal when u first crank it up
Old Oct 10, 2010 | 12:49 PM
devney's Avatar
I honestly think you should change the IACV and then see how both ECU's make your car act after that. Since you said the ECU's are chipped, the idle change between ECU's might have something to do with the map's you have.
When I did my swap, we forgot to repin the harness for the IACV (3 wire to 2 wire). Well I didn't bother doing it for a long time and just the other day I finally wired up my IACV so that I wouldn't throw a code for it anymore and so that my car would start correctly. My car runs much better now. The point that I'm getting at though, is that when I didn't have my IACV wired up, the car didn't idle high when I started it, it just idled normal when cold started, just like you are describing.
Since you say that your IACV is wired up correctly, I would definitely try swapping it with another to see if that gets rid of the CEL. You said that when you plug in the IACV and unplug it the idle changes, so I assume you have it wired correctly.
With your PR4 ecu, are you allowing the car to warm up to see if the idle comes down from 2k?
Old Oct 10, 2010 | 04:28 PM
jimmy o.'s Avatar
With both ecus I ran the same basemap chip just stuck it in the other ecu when I unplugged the iacv with the pr4 it'll act just like the p28 and threw the code
Old Oct 11, 2010 | 06:46 AM
devney's Avatar
Fix the CEL and troubleshoot the ecu issue later.
Old Oct 30, 2010 | 01:37 PM
jimmy o.'s Avatar
Replaced the chipped p28 with a stock p28 no longer throws 14 runs good no jerking guess that was it...
Old Oct 30, 2010 | 04:06 PM
TwoFaced's Avatar
So it was a problem with the chip?
Old Oct 30, 2010 | 09:13 PM
evilclown312's Avatar
Its possible that someone flipped the iac and intake temp sensor plug at one point in time and messed up the ecu!
Old Dec 9, 2010 | 08:41 AM
jimmy o.'s Avatar
Well I put another chip in the p28 it runs the same as before the other regular p28 runs it ok the idle flucates a little sometimes. I dunno my fan dosent seem to ever come on either it dosent overheat tho hmm I guess I need to see if this bugger has a thermostat in it...
vjace
Sep 23, 2007 07:36 PM
allnaturalb16
Jul 12, 2007 03:39 PM
BoBo Racing
Dec 10, 2006 08:21 AM
-+Deez+-
27
Oct 31, 2006 05:49 PM
