05 Civic LX- Stereo deck swap
Have you checked the fuses?
Did you disconnect the battery before you installed the stereo?
Did you cut the harness or use an adapter?
Do the power door locks work if you use the switch on the driver's door?
Your theft system could be tied into your door locks depending on what kind of system it is, and it could be tripped by installing the new deck. Hopefully you used a harness. Disconnect the battery install the old one and see what happens.
brucepick
Oct 4, 2008 03:47 AM
