Spark plug blew out?
Old Oct 9, 2010 | 11:07 AM
Ozzy_Built's Avatar
Icon3 Spark plug blew out?
Hey guys I'm new to the site but I need some help? Any would be a appreciated I have a d16z6 my spark plug blew out of the farthest cylinder on the right facing the motor. I know the threads are done I wanna fix the threads and not pull the head? I know the threads are m14x1.25 for a spark plug but I have been looking at the auto parts store they have the kits but the socket size on most thread chasers is bigger thn a 19mm socket and a 19mm won't fit in a spark plug hole of a d series motor? I also need something thts long enough.....once again I dont wanna pull the head? Any suggestions on what doing or finding a tool tht would fit and also procedures on doing the threads? Thanks
Old Oct 9, 2010 | 01:07 PM
canadaek's Avatar
Default Re: Spark plug blew out?
they sell taps with a 3/8 drive head and you should use a helicoil kit to repair the cly you drill it out larger tap it then install a tread insert good idea to start it with out the plug in to blow out any filings some grease on the tap helps to hold the filings also
Old Oct 9, 2010 | 03:49 PM
Ozzy_Built's Avatar
thnx much
Old Oct 10, 2010 | 06:22 AM
canadaek's Avatar
good luck i will say it's much simpler from the bottom though . tool for ford pickups is a good option as they have deep spark plug tubes also and they have lots of problems with plugs blowing out or siezing in the head.
Shockfire10
Sep 4, 2010 08:43 PM
john457
Mar 12, 2007 06:03 PM
94TealGSR
Nov 17, 2002 12:41 PM
