brakes hot?
Old Oct 8, 2010 | 05:31 PM
93integrab18's Avatar
Default brakes hot?
my dad has a 97 and we changed the lines pads and its not rubbin so what you guys think?? thx
Old Oct 8, 2010 | 05:37 PM
Default Re: brakes hot?
97 teg that is
Old Oct 8, 2010 | 06:08 PM
u guys need more info sry i dnt know much
Old Oct 8, 2010 | 06:23 PM
Drive 4 fun's Avatar
Front or rear or both, and what does not rubbing mean, how did you determine? To get them or it hot, I assume that you mean from driving and braking. Some pads are thick, new and unbedded, and may have had a slight drag. Hot to touch or measured? Trying to get you to look farther and supply more info.
Old Oct 8, 2010 | 06:43 PM
just the front and when u touch it its hot and i was just sayin that there was nothin rubbin that we can tell sorry i dont have much more info. but thx for the help man
Old Oct 8, 2010 | 06:48 PM
You mean one hotter than the other, and do you mean first drive after changing?
Old Oct 8, 2010 | 06:53 PM
Targa250R's Avatar
be professional
Considering that the function of a brake is to dissipate kinetic energy into heat via friction, one would assume that brake components would be hot to the touch after use - the front moreso than the rear, since both static weight distribution and dynamic weight transfer under deceleration dictate that the front brakes bear a majority of the braking load.
In other words, it's normal.
Now, if you can feel a lot of heat radiating from the brake without touching it, then you likely have a sticking caliper.
Old Oct 8, 2010 | 10:08 PM
ok thanks guys i guess thats it my dad dont seem 2 care so i guess its not that bad
Old Oct 9, 2010 | 04:50 AM
Spawne32's Avatar
depends on whether or not were talking about glowing red or just hot, the pads will always be floating just enough to touch the rotor barely at any given time due to fluid tension, if the fluid is old though, brake fluid absorbs water over time, when water gets hot, it expands, and it can move the pads closer to the rotor.
Syndacate
17
May 11, 2010 08:20 PM
R_ACE1
12
Aug 16, 2009 12:53 PM
Flux
May 24, 2005 08:15 PM
