car will not start
Old Oct 8, 2010 | 02:19 PM
2kdrift's Avatar
Default car will not start
So i just installed a new engine i could not get it to start though.
actually its a d16y8 block with a d16z6 head but that shouldn't matter basically same as any d16 motor
so the symptoms are it cranks just fine but wont start and i do not hear any combustion at all
what has been done:
according to my timing light it has spark
has fuel up to the fuel filter(was leaking so i am getting new crush washers, but i dont think this is the problem it should at least try to start.)
Double checked my timing belt was on correct
Pulled dizzy cap saw the rotor is facing #1 at TDC and double checked firing order 1 3 4 2
next:
replace crush washers
check compression
any other ideas guys? one of my major questions would be how to i test the injectors? because i know there is fuel to them and i am also getting spark.
2kdrift
Oct 9, 2010 07:11 AM
neoc03
Jan 2, 2010 10:26 PM
kelviiv
Dec 17, 2008 11:19 AM
dc2doi
Jan 6, 2008 01:43 PM
Lo-Buck EF
Aug 22, 2003 05:40 AM
