ever seen bearings like this????!?!?!?!
Old Sep 19, 2002 | 05:01 PM
jdmhatch94's Avatar
Default ever seen bearings like this????!?!?!?!
came out a gsr block that i bought form a local guy for 800 the block supposely had 2k on it and it has ctr pistons...
[Modified by jdmhatch94, 2:02 AM 9/20/2002]
[Modified by jdmhatch94, 2:03 AM 9/20/2002]
Old Sep 19, 2002 | 05:15 PM
letsride's Avatar
Default Re: ever seen bearings like this????!?!?!?! (jdmhatch94)
What does the crank look like?
Old Sep 19, 2002 | 07:56 PM
LSVTEC96HB's Avatar
Default Re: ever seen bearings like this????!?!?!?! (letsride)
I've seen worse believe it or not, but only because the owner of the car never changed the oil.
Old Sep 19, 2002 | 09:39 PM
b19coupe's Avatar
Default Re: ever seen bearings like this????!?!?!?! (blown96HB)
Looks like the bearings were starved for oil.
Old Sep 19, 2002 | 11:40 PM
riceboy's Avatar
Default Re: ever seen bearings like this????!?!?!?! (b19coupe)
And whatever oil was in there was in there for quite some time.
Old Sep 20, 2002 | 05:16 AM
miller's Avatar
Default Re: ever seen bearings like this????!?!?!?! (riceboy)
did it scar up the crank? bring your crank to a machine shop and let them check out if it has to be cut, at the least you should have it polished. and upon reassembly....plastigage the hell out of it.
johnnyonth3spot
18
Sep 5, 2009 08:24 PM
shrirag
Jul 11, 2007 08:00 AM
ThatsMyEG
10
Aug 20, 2005 05:13 PM
Muckman
May 17, 2004 08:33 PM
redteg1
May 15, 2003 05:20 PM
