d16y8 exhaust manifold on d16a6
Old Oct 8, 2010 | 08:13 AM
redef90si's Avatar
Default d16y8 exhaust manifold on d16a6
I just wanted to confirm if it will fit? and not have any clearance issues with the oil pan?I assume it will because many people do "mini me" swaps with d16y8 head's and d16a6 blocks.Thank you for your time and help;Matt.
Old Oct 8, 2010 | 08:24 AM
munchies91crx's Avatar
Default Re: d16y8 exhaust manifold on d16a6
you should be fine. i see no clearance issues.
Old Oct 8, 2010 | 08:34 AM
redef90si's Avatar
Thanks man,I recently picked up a d16y8 exhaust manifold for a buddy who doesn't want to spend $300-500 on a header right now.I was told it's one of the best flowing stock header's out there for any D series motors.We'll see how it goes.
Old Oct 8, 2010 | 08:35 AM
it is the best of all the d series stock manifolds. there is a faq bout d series power. you should check it out
Old Oct 8, 2010 | 08:42 AM
redef90si's Avatar
do you have a link?I know the b series Throttle bodies are a little bigger and fit on a d series intake manifold as well
Old Oct 8, 2010 | 08:46 AM
yeah ill give ya the link.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-sohc-upgrades-%2Arevised%2A-its-long-work-progress-335078/
that should help with most of ur questions.
Old Oct 8, 2010 | 08:47 AM
redef90si's Avatar
thx a lot man,Have a great day.
Old Oct 8, 2010 | 09:06 AM
Tyson's Avatar
works great. i have the earlier cast version.
the rear support doesnt quite reach but its not that important. you will need to cut out a hole for the dipstick in the heat shield. you should use the heat shield, it certainly helps with keeping what should be hot stay hot, and whats not... not.
anything is better than the stock manifold, that is where all the power is bottled up.
Old Oct 8, 2010 | 05:25 PM
redef90si's Avatar
Thanks for the info man,I have to find him a heat shield
Old Oct 8, 2010 | 05:40 PM
Laserjock's Avatar
I have one and planning to put it on my A6. Just remember that the O2 sensor hole is further back.
Post your outcome
Old Oct 8, 2010 | 05:59 PM
redef90si's Avatar
on the Cdm(Canadian model) it's right at the front,similar to the d16z6 one? If I have to extend the o2 sesnor wire thats not a problem though.I will let you guys notice if I notice any difference.
Old Oct 8, 2010 | 10:51 PM
Tyson's Avatar
you wont need to extend the o2 sensor. its on the #4 runner. the end of the sensor does nearly interfere with the fan, but its ok.
the DC SPORTS Z6 header is at the rear. even then theres no need to extend the wire, just route it over the backside of the tranny.
Old Oct 9, 2010 | 04:57 AM
HondaPartsHero's Avatar
Technical Hero
They're all relatively in the same place in the upper part of the exhaust manifold
D16A6
D16Z6
D16Y8
Old Oct 9, 2010 | 11:11 AM
redef90si's Avatar
thanks for all the help guys;it's much appreciated
Old Oct 9, 2010 | 12:36 PM
jdm ef8 89's Avatar
hmm so its like the closest stock manifold to a 4 into 2 into 1?
I might throw one on mine because im poor.
Old Oct 9, 2010 | 02:28 PM
redef90si's Avatar
x2 I'm all about cheap performance
Old Oct 14, 2010 | 07:58 PM
jdm ef8 89's Avatar
4real build on a budget works almost like a aftermarket header for an si just doesnt look to great.
Old Oct 15, 2010 | 09:01 AM
redef90si's Avatar
Getting new gasket's as we speak should be on the car in the next few days
Old Oct 15, 2010 | 11:04 AM
hondamark35's Avatar
99-00 D16Y8
just wanted to add this to the list of images you have there. i can't comment empirically on the flow (better or worse) but this does weigh the least of all OE manifolds.
Old Oct 15, 2010 | 04:26 PM
fireant's Avatar
Also on the 99-00 tubular-style EX manifolds, the O2 is on the bottom like a DC sports. But like Tyson said, you can re-route the stock wires behind the motor/trans and it will reach.
Old Oct 16, 2010 | 03:17 PM
Laserjock's Avatar
Good info. I have on hand a 99-00 on hand then
Old May 2, 2015 | 04:49 PM
94eg!'s Avatar
#1 Super Guy
Loved
Tyson, do you have any tips on assembly order (Z6 manifold going into my Si)? I currently have everything out including the head & radiator right now.
I was thinking....
- Exhaust manifold
- Radiator
- Fan/shroud
- O2 Sensor
I ask because even the stock A6 manifold was a bitch to get out, and I can't test fit anything until my cylinder head comes back from the shop.
Old May 2, 2015 | 07:08 PM
Tyson's Avatar
Put the o2 sensor on first.
Old May 2, 2015 | 08:39 PM
94eg!'s Avatar
#1 Super Guy
Loved
Thanks, I'll give that a shot.
Old Jul 8, 2015 | 07:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Well I started installing the Z6 down-pipe on my A6 and guess what.... after torquing it against the upper half, I noticed the damn thing had started crushing into my freakin' stock A6 oil pan.
THIS IS BULLSHIT!!! I can't catch a break with this damn car!
