who has arias pistons and installed them yourself... I got some ?'s
Old Sep 19, 2002 | 04:14 PM
infamousALLMTR's Avatar
Default who has arias pistons and installed them yourself... I got some ?'s
putting them together right now but need to know how to get the pin (two circled devil that goes on both ends of piston) I hear you need a tool to get them in... where do I get this tool and how do I get them in ?
Old Sep 19, 2002 | 04:19 PM
poison's Avatar
Default Re: who has arias pistons and installed them yourself... I got some ?'s (infamousRRH)
i'd like to know this as well
Old Sep 19, 2002 | 06:59 PM
Westrock2000's Avatar
if its the two circle clips like what the JE's come with (probably so since it's the same company) than you can use a small screwdriver and inch it in little by little, thats what I've heard of poeple doing. In my case I am putting these (JE's) back onto stock rods and just had the pins pressed back into the rods, the same as they are OEM.
Old Sep 20, 2002 | 08:28 AM
TREVER's Avatar
Default Re: who has arias pistons and installed them yourself... I got some ?'s (Westrock2000)
Arias are not like Je, Je are hard Arias are nearly impossible. Don't be afraid to bend them up a little. use a small flat head screwdriver and push it in then work the clip around until its all of the way in. wipe your blood off the piston and pray you never have to take them out.
nenetech
Jan 2, 2013 09:01 PM
thumper64
Nov 4, 2009 11:58 AM
ys1civicsi
Feb 19, 2008 06:23 PM
NwAmH
May 17, 2007 01:39 PM
97CTR
Oct 17, 2005 05:55 AM
