full float wrist pins?
Old Feb 19, 2008 | 05:48 AM
ys1civicsi's Avatar
Default full float wrist pins?
I am in the market to order some new rods/pistons and was wondering what the wrist pin setup is oem vs. aftermarket I know there are 2 diff. wrist pin setups out there can some please explain them to me
Old Feb 19, 2008 | 10:08 AM
quicksilver1689's Avatar
i ♥ snails
aftermarket is fullfloating with some sort of clips to hold it in place, oem are pressed i believe.
Old Feb 19, 2008 | 11:54 AM
ys1civicsi's Avatar
Default Re: (quicksilver1689)
Do in this case it doesn't matter what rods you would use its all with in the pistons and the wrist pin. And another quick question I was planning on running eagle H-beams with wiseco pistons, so your telling me this will work fine
Old Feb 19, 2008 | 06:06 PM
ys1civicsi's Avatar
Default Re: (ys1civicsi)
bump
Old Feb 19, 2008 | 06:23 PM
NJIN BUILDR's Avatar
Aftermarket rods and pistons are typically full floating and require clips in the pistons to retain the wrist pins.Most oem pistons and rods are press fit and use a press fit between the rod and wrist pin to retain the pin.You can use a press fit rod with a floating pin pistons (but don't use the clips).You can't use a press fit piston with a floating rod (unless you modify the piston to accept clips) because there is no way to retain the wrist pin.
kpjo4
Mar 17, 2010 08:04 PM
kusyurdaddy
Oct 13, 2009 05:35 PM
lsvtec2000
Feb 6, 2009 07:08 AM
DC_Legacy
Sep 8, 2007 07:10 PM
