Power Window & Lock Problem
Hi. I have a 01 honda accord coupe EX. I have a problem with my passenger side window when I lower or close it it makes a clicking noise while moving in a spastic way. It keeps clicking and moving like its having a seizure but it closes and opens but not smoothly, and when this happens my door locks don't work. It happens every so often but not all the time. I tried both sides of the controls and both have the same problem. Wonder if anyone had an experience like this.
Reset the multiplexer system by turning ignition off, set intermittent wiper ring to half way, turn ignition on for 10 seconds and then off.
See link for the multiplexer which is probably causing the problem. But, do the reset instead.
http://www.tegger.com/hondafaq/tsb/accord/x98-071e.pdf
vtec69
10
May 20, 2002 06:45 AM
