Accuracy Of newer Gauge cluster?
Old Oct 6, 2010 | 06:11 PM
89LSED's Avatar
Default Accuracy Of newer Gauge cluster?
I Like the style of the EE Cluster but now with a new motor in it I am worried about the accuracy of the Tac. I will be racing it frequently and i dont want to over tac it.
BUT I WILL NOT PUT A HUGH RICER TAC INTO MY BABY!!!
Are the newer GSR cluster si clusters more accurate on the readings?
Or has anyone ever installed a performance tac into there factory gauge spot?
Or am i way over thinking this?
Old Oct 6, 2010 | 06:22 PM
StayKrafty's Avatar
Default Re: Accuracy Of newer Gauge cluster?
Ive always been under the impression that stock tachs arent very accurate as the needle goes up. Theres plenty of companies out there that make after market tachs that arent huge and ugly.
Old Oct 6, 2010 | 06:24 PM
89LSED's Avatar
I would rather have it look completely stock in the inside. No additions what-so-ever.
But yes, if all else fail that is what i will do.
Old Oct 6, 2010 | 06:27 PM
StayKrafty's Avatar
Ive never had an issue with my current tach not reading right. On my LS, it would read different all the time. Not sure why.
Old Oct 6, 2010 | 06:34 PM
89LSED's Avatar
So far i believe it is correct. But i have nothing to base thast on. no comparison.
Plus with a brand new GSR i dont want to take any chances. I would rather not use my warrenty if possible.
891 more miles till my break in is over!
Old Oct 6, 2010 | 06:39 PM
StayKrafty's Avatar
Gotcha, good luck on finding an answer, not much help in the department. Mine seems to be spot on.
Old Oct 6, 2010 | 08:36 PM
hatchet_honda's Avatar
jeez its not like itll be off by 3k or somethin..like youll be at 9k but read only 6 on the tach..
Old Oct 6, 2010 | 09:16 PM
xtremescouts's Avatar
I dont see how the accuracy of a gsr or itr or even a ek si cluster would be that inaccurate. The itr has a factory rev limit of what around 9000-9500. I highly doubt honda would have made this ability for an engine and not have a somewhat accurate reading on the motor. I have seen a decent amount of cars that run newer clusters and they rev the **** out of their motors with no problems. I also havent heard of many people that still run the oem ef,ed,ee clusters and again rev those motors with no problems.
I dont see why you would need a aftermarket tach unless you were doing a full on race car.
Just my 2 cents
Old Oct 7, 2010 | 12:40 PM
89LSED's Avatar
Im just looking for accuracy
thats all.
And i have to change my cluster anyway because its an auto cluster and if i'm upgrading, i want to get the best one
Old Oct 7, 2010 | 01:09 PM
CRX Toad's Avatar
People use a tach? I just listen to the motor then, got to be one with the car man. 7 years of racing and I have yet to shift in regards to a tach.
Old Oct 7, 2010 | 01:23 PM
2k.civic.si's Avatar
you can program the ecu to also use the check engine light as a shift light...or install a led into the cluster and use a msd window switch to activate it.
fyi the stock tachs are usually off a bit....but only a 200-300 rpm...my si tach is off from my autometer tach by about 300rpm in the higher rpm's.
averyvm
Engine Management and Tuning
Oct 4, 2010 01:33 PM
IntegraGSR311
Jun 21, 2006 09:22 PM
velvetjones
Aug 27, 2003 06:26 PM
