1999 nighthawk 250
Old Oct 6, 2010 | 08:26 AM
Sephrin's Avatar
Default 1999 nighthawk 250
hey guys, i just got this 99 nighthawk 250 and so far it runs good until i get up to about 55 mph. then i starts the sputter or misfire every now and again. it did it about 10 times in a 20 mile ride. i was told by honda there is no oil or air filter to change. not sure where teh fuel filter is at if there even is one on the 250. this is my first bike so i dont know all the mech side of motorcycles yet. any ideas of what could be the cause of the sputter?
Old Oct 6, 2010 | 08:38 AM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: 1999 nighthawk 250
I had the same issue with my Nighthawk, but around 65-70. The best I came up with is the little 22mm carb is starved for fuel at higher speeds since the throttle is cracked open almost all the way 24/7 to maintain speed and the super tiny float bowl runs dry with the quickness. I solved this by periodically closing the throttle all the way for a second or two just to let the bowl fill up completely and then continuing on as normal.
That is of course presuming everything is in working order, so double check your plugs and their gap, and make sure the carb throat is nice and clean.
Old Oct 6, 2010 | 08:42 AM
Sephrin's Avatar
i just put new plugs in them and they were gapped to 0.028 like it said to do for this bike. not sure how to check the carb throat on a bike yet. i have had the bike for about a week and thats all of my motorcycle experiance
Old Oct 6, 2010 | 08:44 AM
Sephrin's Avatar
but it definately sounds like what ur saying is right on the money. it felt like no fuel for a split second and it was only when i was tryin to do the speed limit of 55 out in the cuts. if i backed off to 50 it didnt seem to do it, or atleast not nearly as often
Old Oct 6, 2010 | 08:46 AM
Sephrin's Avatar
also i know honda cars are know for their ability to interchange parts between cars. is there a carb that will bolt onto the 250 that gets better fuel flow?
Old Oct 6, 2010 | 09:01 AM
Kiwibird83's Avatar
Reigning GDD Queen
Not to the best of my knowledge, the Nighthawk 250 hasn't really been changed in any way in the past 25+ years so there isn't even a newer carb design to switch to. The bike should do well up to 60+ MPH without any kind of choking so my best advice would be to pull the carb off and clean out the inside + Re-seal it. You'll find a few "How-To" videos on youtube for it and that should get it running just dandy below 75MPH for just a few bucks and a bit of labor.
Old Oct 12, 2010 | 09:46 PM
carlos92's Avatar
I think you should consult a good mechanic about this problem.may be he can help you out with this.
Old Oct 13, 2010 | 04:21 PM
The_Head's Avatar
hmm, I had a '94 CB250 and never had this problem. Bought it new in '96 and put like 12,000 miles on it in 9 months I wish I had kept it. Great little commuter bike (if you don't mind going slow).
Old Oct 14, 2010 | 07:41 PM
ShaunRR's Avatar
HT White Ops
Community Builder
My fiance's Nighthawk 250 does not have this issue either. Carb cleaning would be my first idea.
jayd4
Honda Motorcycles
May 16, 2010 08:17 PM
Rah Rah
Honda Motorcycles
May 17, 2006 04:22 AM
Hassan'sRR
Honda Motorcycles
Nov 25, 2003 04:43 PM
itr501
Honda Motorcycles
Sep 1, 2002 01:37 PM
2fcknfst
Honda Motorcycles
Apr 17, 2001 07:57 AM
