Transmission & Drivetrain Gearboxes, Differentials, Clutches
b16 wount go into gear
Old Oct 6, 2010 | 06:13 AM
DA john's Avatar
Icon2 b16 wount go into gear
i have a b16 tranny in my DA and when i put it into gear and come off the clutch it its like a grinding rubbing sort of sound. all the gears are the same even reverse. i can put it into gear with the car off and it will still roll back. my buddy said that its probably my pressure plate but i just wanted a second opinion. should i fix the b16 or would i be better off buying a gsr (im going ls turbo soon and i dont think the short b16 gears would be too good boosted).
Old Oct 6, 2010 | 06:28 AM
Honda Bull's Avatar
Default Re: b16 wount go into gear
Based on the limited amount of info you're providing, I would say clutch or shift linkage.
When did this start doing this?
Did you just put the trans in and it did it?
Or were you driving on it for a while and it started?
Did you have the LS trans driving fine on the same exact linkage?
Do you have the correct linkage installed correctly?
Etc.?
Old Oct 7, 2010 | 06:24 AM
DA john's Avatar
sorry for the lack of info, i was in school and trying to write it before class ended.
the b16 was in the car when i bought it and it was all good until 2 nights ago when i was driving to work. i stopped at a stop sign and went to put it into first gear at like a 2mph roll. i heard a little pop sort of sound and then it was like a grind rumble sort of sound when i came off the clutch. im pretty sure the linkage is fine because i was driving it for a few months with no problems at all. and the kid i bought it from said he had just put in new shift linkages about a month before i bought it, as well as a new clutch.
Chops13
Jan 9, 2013 12:32 PM
Tkthedk
Oct 14, 2011 02:06 PM
seanclark
Jan 26, 2006 01:08 PM
GTWITIT
Apr 27, 2005 09:56 AM
98gsrTEG
Apr 3, 2005 08:11 AM
