F/S: Skunk2,Turbo, Bisimoto etc good SOHC turbo stuff
Old Oct 5, 2010 | 03:10 PM
MagnaniEG6's Avatar
Default F/S: Skunk2,Turbo, Bisimoto etc good SOHC turbo stuff
Selling these for my friend. He is out of Honda if you want a 1993 Civic Si with lots of suspension stuff for sale pm me.
Interior
• Boost gauge (Defi BF ) & Control unit (Defi BF )
• AEM WIDEBAND
• Oil Pressure (Defi BF )
• Oil Temp. (Defi BF )
• Greddy turbo timer 2 $100
• 3 Gauge Pillar and 1 single $30/$20
• Greddy Boost control N/A
Oil feed and return line
• Oil feed 50
Intake Mani
• SKUNK2 INTAKE MANIFOLD 245
• HEAT SHIELDING INTAKE GASKET 50
Wastegate, BOV
• tial wastegate 38mm 255 firm
• BOV
Pistons, rods, bearing, all gaskets, 75.5mm (AKA bottom end stuff) 629
FJ R Spec Custom Length D16 I Beam Connecting Rods
-ARP 2000 3/8" Rod Bolts
-ARP Lube
-YCP Vitara pistons (75mm / 75.5mm / 76mm)
-Wrist pins and C clips
-Piston rings (Hastings or NPR)
-OEM Timing Belt
-Japanese Water Pump
-ACL Race Rod Bearings
-ACL Main Bearings
-ACL or King Thrust washers
-Full engine Gasket & Seals set--> Its all the gaskets and seals you will need for your engine from the oil pan and up to the head. Metal 3 layer Head gasket (approx .030 thickness)
Head stuff
• APR Head Studs 100
• BISIMOTO Race Valve Springs and Retainers 365
• Supertech Stainless Valve Set I/E 250
• Supertech Valve Guides I/E 85
• BISIMOTO LEVEL 3.6 Camshaft 450
• BISIMOTO Engineering Cam Gears 140
• Blox Cam seal 16
Turbo
• Garrett T3/T04e 50 trim 630
Fuel Stuff
• Precision Turbo fuel injector 1000CC
• Fuelab 515 Series Fuel Pressure Regulator -10AN Inlets /Standard Seat / EFI (25-90 PSID)
• Golden eagle Fuel Rail 130
• WALBRO FUEL PUMP 255LPH WITH INSTALL KIT 110
Trans
• OBX LSD 375
• LSD Moto. Fly wheel 190
• LSD Moto. Clutch 250
Motor mounts
• HASPORT ENGINE MOUNT KIT 92-95 ~~ 70a 300 firm
Motor Oil
• 4 Torco TBO Premium Break-in Oil 30SAE not sure look them up
8 torco sr -1 racing synthetic 5w30 i pay 115 for everything sll oil
Old Oct 5, 2010 | 04:28 PM
hrs-parker's Avatar
Default Re: F/S: Skunk2,Turbo, Bisimoto etc good SOHC turbo stuff
bump for some nice parts!
Old Oct 5, 2010 | 04:43 PM
integradc4_rg87's Avatar
how much for the wideband
Old Oct 6, 2010 | 08:10 PM
MagnaniEG6's Avatar
ttt
MagnaniEG6's Avatar
all gauges are sold
Old Oct 7, 2010 | 11:14 AM
joexiong's Avatar
what kinda clutch is that? or brand. isn't lsd motor a store.
Old Oct 7, 2010 | 03:21 PM
MagnaniEG6's Avatar
lsd motorsports. I had the same clutch in my b18c its good and cheaper then other brands
beginmyhonda
Jul 1, 2011 11:59 PM
MagnaniEG6
Jun 14, 2011 04:03 PM
oMek
Feb 15, 2004 10:29 AM
95turbohatch
23
Feb 8, 2004 02:25 PM
mntdewred
Oct 14, 2002 06:41 PM
