Sohc turbo - Pistons, Rods, Bearings and ring questions..
My car: 1995 Honda CX hatchback
Motor: jdmd15b vtec
Mods: Sohc greddy kit, greddy small FMIC, turbo timer, type S bov, air/fuel, oil pressure, boost guages, thermal R&D catback.
Mission:
run 12 psi plus (possible on new turbo (20g was recomended) but for now on 15g
225++whp
Plans:
Send block (with all bottem end components) to NRG (good guys) for bore/hone/hottank/assembly
Bore .20 over
Use eagle rods and je pistons (recomended for good budget, yet not cheap build)
Arp studs
OEM headgasket
OEM bearings and whatever rings
INline4 bottom end gasket kit
turbo XS (or other brand) mbc
Hondata s200 w/ boost
Dsm 450s with resitor box
Tuning
Questions-
1. Was wondering what Size pistons to use with the .20 over stock bore??
2. What bearings/gaskets/rings need for bottom end assmebly? All oem Good?
3. Anyone used thepartsbin.com, and if its reall OEM stuff, and if so, how did u Like it and whats service like
All responses are greatly appriacited..
Re: (95turbohatch)
you might be able to get stock ls pistons machined to your block if your sending it in, there cheaper than getting forged pistons and there boost friendly.
NO ls parts.
I am getting forged pistons and eagle rods..
i just need to know the stock piston size??
CAN ANYONE HELP ME ON THAT..
Modified by 95turbohatch at 5:32 PM 2/4/2004
Re: (95turbohatch)
hey bro if you ever find out let me know too....REALLY INTRESTED IN BUILDING MY STOCK d16z6............want about 200-225 horse power on the greddy kit.....
Re: (kiddcheng)
guys if your lookin for 200-225 on your blocks you dont need to build them um, just go with a block gaurd and some good tuning, maybe a 2mm head gasket, other than that you can hit 200 225 hp on like 10 psi good luck though.
Re: (ueatdooki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ueatdooki »</TD></TR><TR><TD CLASS="quote">you might be able to get stock ls pistons machined to your block if your sending it in, there cheaper than getting forged pistons and there boost friendly.</TD></TR></TABLE>
LS pistons = 81mm
SOHC = 75mm
That's a HUGE OVERBORE to fit B series pistons in a SOHC!
But for the questions:
1) Check with the piston manufacturer that you're going with. Most can do customs sizes, or have popular sizes in stock.
2) OEM always.
3) Never used it, sorry.
LS pistons = 81mm
SOHC = 75mm
2) OEM always.
Ill go with my build up i was going to do, not just a blockguard and a headgasket at 10-12psi bound to blow something up ..
thanx anyway for the info I GOT A QUESTION.
Re: (95turbohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95turbohatch »</TD></TR><TR><TD CLASS="quote">Ill go with my build up i was going to do, not just a blockguard and a headgasket at 10-12psi bound to blow something up ..
thanx anyway for the info I GOT A QUESTION.</TD></TR></TABLE>
Sure man anytime, btw good luck with the buildup and I hope you meet and surpass that 225hp goal
Re: (yellowfever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowfever »</TD></TR><TR><TD CLASS="quote">bump. SO hed want 75.20 mm pistons correct?</TD></TR></TABLE>
NO!
20 over is in thousands of an inch.
0.020 over is actually 75.5mm
Common overbore sizes on stock sleeves are 0.010 and 0.020 over, or 0.25 or 0.5mm
I will be running 77mm pistons on my sleeved rs block, and I m selling a sleeve 75.5mm GE Sleeved ZC
NO!
Re: (95turbohatch)
have you heard/read this thread...
https://honda-tech.com/zerothread?id=267641
It's a guy selling machined b16a rods with toyota pistons (forged)...
He's run pretty high boost with nothing but those and a thicker headgasket....
Re: (95turbohatch)
Why are you rebuilding your motor? D series motors arent as weak as everyone makes them out to be, 225-250 whp is safe on a stock motor. The sleeves are exactly the same as a b series motor, the only weak point is the rods. If i were you, I wouldn't do a rebuild unless the motor is already toast unless you want 300+ whp. Tuning is the key to keeping a motor healthy, not building it like a brick shithouse.
I am prob going to go with this piston / rod assembly i read the thread alot of positive responses about turbopanda and his work
and i am still doing all my other plans above.. thanx for the info
95turbohatch
02-09-2004 08:14 AM
