please check my stock d16y8 turbo crome bin =)
Old Oct 5, 2010 | 10:07 AM
rndmheroxx's Avatar
Default please check my stock d16y8 turbo crome bin =)
okay so im not soo concerned with my afrs, i know i need some tweaking there, but that part is pretty straight forward to me. im running a chipped p28 with crome, and I'm installing a knocklite this weekend to see if i cant figure these timing maps out. *edit- also using freelog to log afrs and check timing* just looking to see if my maps look good right now and i dont have a timebomb on my hands. I have the mechanical timing set at 12* and the ecu at 21* base. ill throw up some screenshots, but would definitely like if someone wanted to grab my whole bin and look it over. please dont tell me to take it to a tuner or whatever, this stuff fascinates me and I want to get ever drop of knowledge i can on this subject even if people have to flame me to do it thanks for your time
setup:
d16y8 stock
custom mini-ram
garrett t3/t04e 57 trim
tial 38mm @ 7psi
dsm 450cc
walbro 255
Precision 350hp IC
2.5" dp/testpipe/catback
innovate lc-1
blitz bov
p28 chipped by me, moates ostrich and xtreme hulog
Old Oct 5, 2010 | 10:12 AM
rndmheroxx's Avatar
Default Re: please check my stock d16y8 turbo crome bin =)
okay so here is the bin I initially tuned the car on, i started with a bin i found on xenocron and tuned it from there, i had the mechanical timing at 16* for this one.
http://www.mediafire.com/file/2r8xow...ngerfUUUCK.bin
and this one I havent run in the car yet, I just wanted to start from scratch so I could get the feel for creating one, plus this way i could put my dizzy back in the middle instead of cranked all the way towards the firewall. ( the screenshots are from this bin )
http://www.mediafire.com/file/8d3wf0...lld16turby.bin
Old Oct 7, 2010 | 06:46 AM
rndmheroxx's Avatar
bumpp.... im getting nervous lol. I dont like not having my baby when im away at school haha. I always read about other peoples problems then want to go run out and check to make sure shes okay and I cant cuz shes 3 hours away =( going home this weekend and really want to know how my timing looks especially on the bin I tuned it on cuz im worried about cracked ringlands now.
Old Oct 11, 2010 | 04:23 PM
rndmheroxx's Avatar
bump =/
Old Oct 11, 2010 | 06:01 PM
2k.civic.si's Avatar
only way your going to set timing properly is on a dyno.
Old Oct 11, 2010 | 07:21 PM
rndmheroxx's Avatar
i just want to know if my concepts are correct and if my maps look somewhattttt okay?
Old Oct 18, 2010 | 12:35 PM
ZAN_TUNING's Avatar
Your fuel maps are a little splotchy so don't be suprised if you get a couple hiccups under boost. Your timing is ok but you won't know what it truly wants until you get on a dyno and watch the torque curve.
Old Oct 22, 2010 | 07:49 PM
HAMOTORSPORTS's Avatar
First things first, I'd set your distributor base timing to 16 degrees. Use your software to make changes from there. Remember that adjusting your distributors 'mechanical' base timing also affects your injector opening and closing times in relation to engine position...
also, you WILL need it on the dyno to verify your timing is ideal..
Canadian_EF
10
Apr 15, 2012 06:29 PM
honisoto
Jan 24, 2009 04:01 AM
EK_kidd
Engine Management and Tuning
Nov 15, 2008 12:07 PM
ironcheftony
Oct 12, 2006 04:32 PM
PHiZ
Jun 2, 2005 11:40 AM
