type-r 36mm axle question
i have 36mm axles on my car and the axle boots are ripped. Instead of buying used 36mm axles is there anyway to replace the boot and from what model car can i get it from.
they make universal boots. many auto parts stores carry them. just give them the dimensions and they can match them up as best they can.
although i'm sure there is some kind of other car make of axle boot that would match it exactly
problem being the axle is from the JDM type r and has 36mm hub, so no US auto stores will have replacement axles, just get the boot replacement kit for the integra, the normal axle shaft is the same size up until the hub part...
doesnt mean u cant get an axle that will fit, jus cause its jdm doesnt mean they dont make the same size axle in the US , there are part stores out there that will have the right size axle for you, u just have to look around
look for driveshaft shops near you. they have boots in stock of every size and usually 45-50 to make you axle like new
