bbs rs question.
Old Oct 4, 2010 | 08:35 AM
Ludey849's Avatar
Default bbs rs question.
i got original rs 001's. If I put 1.5 lips on it, it turns into 7.5 Width and what offset?
Old Oct 4, 2010 | 10:45 AM
r.wright's Avatar
Default Re: bbs rs question.
im not too familiar w. the diff rs models( iirc my old rs001's were +25) but i do know that if you add an inch of lip the offset (in most cases) will go down about 12mm. if you add .5" it will go down approx 6mm.
so if u had 15x7 +25 rs001 n u added .5" of more lip(7.5j) you will be down to approx +19 offset
so if u had a wheel w/ a +25 mm offset n 4" lip and u replaced the lip with a 5" lip your new offset should be approx +12mm.
so by adding .5 of lip u take away about 6mm
by adding an inch u take away about 12mm
Old Oct 4, 2010 | 12:09 PM
Ludey849's Avatar
ya mine are +25. so its minus 6.
im planning on running 2in in the back and 1.5in the front.
so end result would be this, correct me if im wrong.
7.5/+19 FRONT
8/+13 REAR
Old Oct 6, 2010 | 01:48 PM
r.wright's Avatar
sounds about right to me
Old Oct 6, 2010 | 03:42 PM
88vr's Avatar
ya your right. GL
Old Oct 6, 2010 | 07:17 PM
Ludey849's Avatar
thanks guys
k7q
Mar 4, 2010 12:38 PM
uses0ap
May 8, 2009 03:29 AM
Myh4tch
Oct 7, 2003 08:01 AM
slammed_93_hatch
Jul 17, 2003 11:27 PM
