In Need of help! engine grimlins 87crxsi
so was driving up a hill in my 87crxsi... and the pgm fi light comes on, car starts to crap out and the throttle wont respond, pulled over, everything looked fine. could make it get up to speed if i slowly feathered the throttle down. so thought it was the fuel filter was clogged. got a new one. still idled rough, so pulled the plugs, oil fouled. cleaned up nice and shinny. cleaned up the ports on the distributor cap.(inside rotor too)
and now it idles better... but the whole damn car shakes... like dash is going pretty good. and if you try to gas it fast. not even fast just fairly fast it bogs and back fires... been trying lots of things. ran injector cleaner through it. bleh still **** up...
any suggestions?? im out of ideas
so turns out its running on 3 cylinders. not sure what to do from here. i have another 87 crx for parts. take all the injectors and what not from that one and put them on the one i drive?
Screw you guys, I'm... going... home.
It helps to add your location to your profile, since local peeps might be willing to lend a hand or tools. There are lots of things it could be, but the first things I would check are the timing, compression, and fuel pressure. Are you sure the timing belt didn't jump a tooth? Make sure all of your vacuum hoses are still good and not cracked.
freeagent314
Oct 8, 2008 08:02 AM
Evolution Type R
12
Aug 4, 2006 09:19 AM
thehondabuddy
Nov 14, 2003 11:33 AM
