Turbo DD Setup
Old Oct 3, 2010 | 12:16 PM
98tegLSvtec's Avatar
Default Turbo DD Setup
Hey so i have (2) integra LS's think about selling the one and keeping the turboed one as a daily driver, its a 9:1 compression motor with all je pistons eagle H beam rods and that so it should be just fine with boost. BUT what should i run for a turbo for daily use?
Old Oct 3, 2010 | 12:24 PM
AlexDphoto's Avatar
Default Re: Turbo DD Setup
imo, a good daily driver turbo car is one that will still give you good gas mileage, and give you the power you want without too much lag.
For instance, when I built my turbo teg, I built it with daily driveability in mind.
I went with a turbo that spools decently quick, but not so small that when I accelerate in traffic from a stop light that I wont be in boost instantly, but I didnt have to wait till 5K plus to see full boost.
Knowing I wasnt aiming on making 500+whp I kept my compression ratio at stock gsr compression, and bumped displacement a **** hair to 81.5mm. This way my car isnt a dog when its outside of boost.
I see about 290-300 miles to a tank before I have to refill, thats with mixed driving, id say 30% hwy 70% city.
Full boost for me is 4400rpm with a garrett gt32 and your run of the mill log manifold.
Id suggest something along the lines of a 57 trim to keep things simple, although there are plenty of turbochargers out there that will be just as good if not better ( precision 5857, borg S256 etc.)
Old Oct 3, 2010 | 01:22 PM
Alrighty so basically, i should put my old LSV motor back in thats pretty much stock compression and get a .50 right now i have low comp. and a .60 trim setup but its quite laggy
Old Oct 3, 2010 | 01:57 PM
98integralsB18's Avatar
the one with a built bottom end is perfectly fine. just run it on 8 to 10lbs of boost and get it tuned and youll be good to go. you have a built bottom end you could do more but thats up to you. do not swap that lsv motor back in it.
Old Oct 3, 2010 | 02:27 PM
AlexDphoto's Avatar
a 60 trim really wouldnt be all too bad, if you want a bit of a quicker spool you could always use a log manifold or mini-ram which are more direct flowing manifolds to get it to spool a little sooner.
I would just keep the built bottom on there.
Old Oct 3, 2010 | 03:05 PM
there both built, its just that one has 10:1 or so and the other one has 9:1 comp
Old Oct 3, 2010 | 03:08 PM
its basically the choice between more or less stock compression and low compression, i understand that a lower compression can handle way more boost and abuse. but im currently having trouble selling the higher compression motor and need to sell one....
Old Oct 6, 2010 | 12:39 PM
ScorpionT's Avatar
If you plan to use one as a DD, keep the high compression car. Higher compression will help with spool. The lower compression I would keep if it were for the track or making more power.
Old Oct 10, 2010 | 01:56 PM
[Id suggest something along the lines of a 57 trim to keep things simple, although there are plenty of turbochargers out there that will be just as good if not better ( precision 5857, borg S256 etc.)[/QUOTE]
.57 trim is prolly going to me in my price range.lol
Old Oct 10, 2010 | 01:58 PM
I was kinda feeling the same way, Hate Turbo lag but im assuming when making 350+whp its a blast and well worth the wait, but im not looking for that kinda power for my dd.lol
Old Oct 12, 2010 | 11:54 AM
elliott_holtGSR's Avatar
a borg warner or garret .57 trim would probably fit your needs just right for daily use. 10psi on built motor should be right around 300whp with a good tune and on a vtec motor. I had one before i went bigger and i would get full spool around 4,000rpm. The only thing i hated is that no matter when your putting your foot on the gas you get spool which dosnt help your gas milage that much lol
Old Oct 12, 2010 | 02:42 PM
Its funny you say that, because i was telling a friend of mine those exact words..
But anyway, what was your best miles per tank with 10psi on the .57 trim? And do you think I could get by with the 450 blue tops or would that be to high of a consistant flow rate? (need I mention I only get on it when I have to)
Old Oct 12, 2010 | 03:11 PM
Jimmy's Avatar
Global Moderator
It's all in the tune. what whp #'s are you looking to achieve?
Old Oct 12, 2010 | 04:03 PM
A quick spooling 300whp
Old Oct 12, 2010 | 06:23 PM
90HondaDA's Avatar
you can get that on like 8 psi
Old Oct 17, 2010 | 10:05 AM
Yea I probably could
TEAM JDM-P
Oct 26, 2009 03:52 PM
92civtegra
Aug 15, 2007 08:26 PM
Dasani
Jul 7, 2006 05:13 AM
MobRacing2
Feb 24, 2006 06:43 AM
TurboTeG4
May 10, 2003 08:02 PM
