wont start
hi peeps i done a stupid thing a painted my rocker cover on prelude 95 and i put it back togeather and it wont start ???? also i rounded two of the rocker cover nuts so would that be why it wont start ? but it sounds like the spark plugs not fireing to me can any one help??????? thanks aaron.
is that the little wire that sits on the side of the rocker cover (vale cover ) cos i took it off to paint it but i scratched the paint off where the wire sits im just running out of ideas and i dont no what i done wrong lol thanks
check fuel pump to see if its priming, fuel pressure regulator? look for all disconnected plugs? try spraying some carb cleaner in the throttle body while someone else starts it up.
yea i have done that a looked it over about 3 times i looked at the main rely but it looks a bit brown around the joints but could not see any cracks how many clicks should it make just the one
I can't think of anything else that you would have touched to get the valve cover off. I went through the steps in my head and even the honda technical guide, but outside of the ground wire and plug wires being in the wrong order i can't think of what would be stopping the engine from starting.
34 4321 is the wire orders, if you wanna double check.
12
12
Heres a simply test to see if you have spark to each cylinder or from the coil to the distributor. Remove one spark plug wire and start your car. If you see sparks/voltage come out the wire, then it should be working properly. Take the ignition coil wire and do the same. No voltage or spark?
ignition coil is by the dist. it should go ignition coil, and a wire to the bottom of distributor cap. pull that off where it is connected to the distributor cap. and check for voltage/spark
yea it is i tryed to put in a diffrent place but still no luck the only other thing i can think of doin is to sand the whole vale cover down again as i sprayed it red and that must be stopping the spark some how
wtfbrok3n
Jul 19, 2009 09:45 PM
Japanman2009
Oct 6, 2008 03:15 PM
DougNuts
Jun 26, 2005 02:50 PM
