limp mode help please
i have a 00 prelude with a a f20 motor with an h22 intake manifole system and obd11 computer n wiring now i was getting a crank position sensor code i change it bc i went in to limp mode n then i got a v teck solenoid code too so i changed both parts n im still in limp mode the car wont go past 3 rpms in any gear unless i turn the car of to the one click before you actua strt the car with the key then put it right in the full on position for one sec . i do this while the car is moving and aproching 3rpms n then it gets out of limp mode but once i let it fall below 3 rpms it goes right back in to limp mode meaing it stutters n wont go past n it you actualy gear down then allow the rpms to drop but knowing how the compression increases the car has no energy to accelerate untill i turn the key again . i was told to flash my car but i dont know how or where to go to get it done can some one help
i just replaced the entire solenoid n oil presure switch and the crank position sensor that were giving the codes n now i cant clear them i even trien removing the battery for an entire day nothing works the codes still showing up even though the parts have been replaced . wat can i do now ?
Granny_shifter
18
Sep 17, 2012 08:08 AM
