Transmission & Drivetrain Gearboxes, Differentials, Clutches
Reuse diff bearings from one diff to another
Old Oct 2, 2010 | 09:35 AM
vinuneuro's Avatar
Default Reuse diff bearings from one diff to another
Is there anything wrong with pulling the diff bearings off the original and installing them on another that'll go in.
Old Oct 2, 2010 | 04:19 PM
94EG8's Avatar
Seagull Management
Default Re: Reuse diff bearings from one diff to another
I've done it before, if the bearings are good it shouldn't be an issue.
Old Oct 2, 2010 | 04:51 PM
vinuneuro's Avatar
Does this go for all the bearings in the trans (swap from one into another)?
Old Oct 2, 2010 | 05:07 PM
94EG8's Avatar
Seagull Management
I've reused everything before, got caught on the last transmission I did though, replaced the obviously bad bearing with a new one from honda, checked all the others, everything seemed good, assembled transmission and installed, still have bearing noise.
Old Oct 2, 2010 | 08:58 PM
Aquafina's Avatar
Don't reuse the diff bearings.
Old Oct 3, 2010 | 08:45 AM
94EG8's Avatar
Seagull Management
Any particular reason other than you don't like running used parts? Or is there something else i'm missing.
Old Oct 3, 2010 | 09:38 AM
Honda Bull's Avatar
Depends on the setup and mileage I suppose. If it's not anything that is going to sustain a lot of power or abuse, you'll be fine provided they are in good shape and haven't suffered from any debris. Ball bearings are pretty resiliant bastards as long as everything was maintained and you get them off/out properly.
Old Oct 4, 2010 | 04:45 PM
Evs-One's Avatar
Solbros Owns Me
You usually end up spreading the races wide when removing the diff bearings and shouldn't re use them. Just buy new.
B17SolRide
Mar 20, 2018 07:05 AM
canadaek
Nov 6, 2012 02:05 PM
huge230
Feb 28, 2008 03:44 PM
John
Jul 5, 2002 08:52 AM
