Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
what should the cam gear look like tdc?
Old Oct 1, 2010 | 02:11 PM
949's Avatar
949
Default how many tooth can be off for the engine not to turn over?
i just did a new crank pulley oil seal replacement. the car isnt turning over now. no cel lights.
nothing else was changed or touched other then cover off. so that i can remove the cam cover.
im thinking its the tooth off from the timing belt.
any other suggestions it could be?
starter works. flywheel is turning.
Old Oct 1, 2010 | 02:52 PM
949's Avatar
949
Default what should the cam gear look like tdc?
on a 1.7 02 ex civic. sohc.
what should the tdc cam gear look like?
i did the long screw driver test in cylinder 1 and when it hits peak the two horizontal lines on the gear isnt parallel with the head.
any illustrated haynes link avail?
Old Oct 1, 2010 | 02:55 PM
It Wasn't Me's Avatar
Default Re: what should the cam gear look like tdc?
There's a picture in this link from the FAQs
Timing Belt / Coolant Flush / Water Pump: Link
EDIT: Don't click this link, click the one in the post below.
Old Oct 1, 2010 | 04:02 PM
949's Avatar
949
the link doesnt work
http://www.****************/forums/3...t-diy-2-a.html
Old Oct 1, 2010 | 04:12 PM
Try it again, it should work now.
lurice01
12
Feb 22, 2017 07:56 PM
DumpdEJ6
Sep 12, 2010 08:05 AM
crazy_civic_man
Dec 29, 2004 05:35 AM
jweller
Jun 6, 2003 08:37 AM
Sinner
May 28, 2003 09:31 PM
