Blox Shifter issue
Old Oct 1, 2010 | 08:00 AM
Ken99287's Avatar
Default Blox Shifter issue
Hello guys, I just bought a new Blox single bend shifter locally from someone. It has never been installed and is new in open box. I just noticed last night, a few days after I bought it, that one of the bearings is not spinning smoothly.
On one side, there is absolutely no resistance. On the other side, I can feel it catching or grinding just slightly. I see a size number on the bearing, so I'm guessing they are changeable.
Any ideas on how to get it out??
Old Oct 1, 2010 | 08:27 AM
B16-CRX's Avatar
Default Re: Blox Shifter issue
mine used the same bearings as a skateboard. just pop the old ones out with a punch
Old Oct 8, 2010 | 02:47 AM
Ken99287's Avatar
The issue is there's nothing to grab with the punch... the inside of the bearing is almost flush with the middle of the hole...
Old Oct 8, 2010 | 08:22 AM
TJChad's Avatar
There is a hole straight through the shifter though correct? Can you not push a punch through the opposite side at an angle and grab a peice of the lip?
Old Oct 11, 2010 | 01:43 PM
Ken99287's Avatar
That's what I'm talking about. There's nothing to grab when looking into the hole at the bearing on the opposite side. It's flush - or at least flush enough that it will be very very difficult to grab enough...
cmross13
Transmission & Drivetrain
Jan 25, 2010 07:05 PM
rutherfordhigh
Oct 27, 2008 10:42 AM
hectic57
Feb 27, 2008 08:16 PM
Extreez
Dec 8, 2006 06:08 AM
snouka
May 5, 2006 11:22 AM
