Timing ? Pressure in system
Old Oct 1, 2010 | 06:00 AM
cardinalredeg's Avatar
Default Timing ? Pressure in system
Pressure in the system no sign of a headgasket leak but I just started learning tuning. But my question is if u run to much timing can that cause pressure in the system checked the plugs no antifreeze on them any help that could lead me in the right direction would be awesome . Iam also new at this so if u have a smart comment please leave it to your self just trying to learn thanx again
Old Oct 1, 2010 | 06:51 AM
likwidchz's Avatar
Default Re: Timing ? Pressure in system
I really have no idea what your asking.
Old Oct 1, 2010 | 07:19 AM
Can running to much timing cause pressure in your coolant system like I said I'm new at this and if I wording it incorrect sorry
Old Oct 1, 2010 | 07:31 AM
likwidchz's Avatar
It will not cause too much pressure.
Old Oct 1, 2010 | 08:33 AM
Ok thanks so it must be a head gasket
Old Oct 1, 2010 | 10:00 AM
Mattb16teg's Avatar
Community Builder
Community Influencer
or the radiator cap..............
When you open the cap does it sound like a shaken up 2 liter?
If so the cap is bad because it is not relieving pressure.
Old Oct 1, 2010 | 11:25 AM
i thought it could have been that so i put a brand new cap on it
Old Oct 1, 2010 | 07:20 PM
adamrich33's Avatar
did the cap help, is it running hot? you might get more help in the tech section.
Neo218
Mar 19, 2010 07:39 PM
carnage_uk
May 13, 2009 10:03 AM
steveharrmr23
Oct 17, 2008 12:28 PM
92SiB18C1
Apr 9, 2003 06:40 AM
Quik89Si
Aug 16, 2002 08:30 AM
