boost that pyr
Old Sep 30, 2010 | 09:16 AM
VTEC_PRODUCTION's Avatar
Default boost that pyr
A friend of mine who owns a PYR teg wants to boost his stock motor. i used to have an ls teg but moved on to an STI so i still have an account on here and i want to help him out. He doesnt have too much of a burn for high hp but he wants to boost his stock c5 either sc or tc and i told him that he can piece together a turbo kit on a budget. you guys have any suggestions? any input would be awesome...
Old Sep 30, 2010 | 09:37 AM
mafi83's Avatar
Default Re: boost that pyr
Boosting an R is NOT my cup of tea. I think it upsets the balance of the caR. Build her up NA I'm sure he'll enjoy it even more.
Good luck!
Old Sep 30, 2010 | 09:41 AM
Todd00's Avatar
I said I don't want a title!
Tell him to sell the car and buy something with a turbocharger already on it. Boosting an R on a budget is a bad, bad idea.
Old Sep 30, 2010 | 09:48 AM
BlueIntegraBoy's Avatar
b00st = b00m
Old Sep 30, 2010 | 10:42 AM
fastvtecCL's Avatar
My stock block R has been boosted for 5+ years with no problem... i pieced my turbo kit together with help from RLZ here in NC.. "most important thing is a good tune"
My setup
precision Sc50 turbo
RLZ 3mm headgasket
toda valve springs
880cc injectors
255lb fuel pump
mugen exhaust
EVERYTHING ELSE IS STOCK !!!!
Old Sep 30, 2010 | 04:06 PM
PaulMc's Avatar
Painfully Stupid
You have to have a pretty high budget because something always goes wrong and you need to be prepared for things you think you might not need to worry about now. When I have the extra 10k the first thing I'm going to do is boost. When you go all motor you spend so much cash and get little gains, nothing against the NA guys but I want the power as well as the handling.
Old Sep 30, 2010 | 04:21 PM
gosu08's Avatar
If you are on a budget, I suggest you go JRSC as you can find one for fairly cheap. $1500 or so.
If you are going to build a turbo kit, save your money and do it right the first time. You dont want to get an okay setup and have problems or when you want to upgrade, you have to change manifolds etc. You will run into more problems.
Old Sep 30, 2010 | 04:43 PM
Todd00's Avatar
Boosted ITRs are fun, but it totally changes the dynamic of the car (for better or worse). I'd do a lot of research before you chose that path...
Old Oct 1, 2010 | 08:16 AM
where?
when i say budget build im not expecting it to be cheap and neither does he. really we want everything total under 4grand...
Old Oct 1, 2010 | 09:23 AM
RGoose18's Avatar
Exactly, you'd have to dump a boatload of cash to make it reliable both on the track and around town. Tell him to swap a b18c1 in and butcher that, I wouldn't boost a C5.
Old Oct 1, 2010 | 10:58 AM
PaulMc's Avatar
Painfully Stupid
My advice 100%. Keep the C5 fresh and OEM.
Old Oct 1, 2010 | 12:09 PM
gosu08's Avatar
where?
Just look here on HT. Do a little search and many for sales will come up. I recently sold my JRSC on here too for about that price.
With 4k, you can build a decent turbo kit but its going to take more than that to buy quality parts unless you want to buy used.
Ram horn manifold (1000+),
Turbo (700+)
Hondata (500+)
Intercooler (500+)
Tuning (500+)
Just looking at those components not inluding BOV, waste gate, intercooler piping, oil pan, labor, etc etc. You are looking at over 4k IMO.
I have went through both JRSC setup and low and high power with turbo.
Old Oct 1, 2010 | 06:21 PM
DOHc SIdE's Avatar
Boosting a type r should be against the law. The car was not built for that you should tell him to sell it and buy GS-R and boost that.
Old Oct 1, 2010 | 08:40 PM
PaulMc's Avatar
Painfully Stupid
And an EK wasn't built to swap motors in and out of and run 11's in..
Old Oct 1, 2010 | 09:04 PM
HYREV2NR's Avatar
I have a wanted to turbo charge my ITR for quite some time and yes I got bit by the boost bug. But I'm starting to ask what it's worth even if I don't daily drive it. But if I do go the turbo route I have a C1 motor to use and abuse. My old SC was fun but bad tune = BOOM!!!
Old Oct 1, 2010 | 09:06 PM
RGoose18's Avatar
You're sacrificing track duty reliability w/ a boosted R, if the owner is comfortable w/ that then go for it.
How well does a C1 mate w/ an ITR tranny btw?
Old Oct 1, 2010 | 09:31 PM
HYREV2NR's Avatar
Any B series motors and trannys will interchange.
Old Oct 4, 2010 | 12:13 AM
forcefedferio's Avatar
Turbo (700+)
Hondata (500+)
Intercooler (500+)
Tuning (500+)
You can definetely do it under 4 grand, especially if you can score some used parts. you don't HAVE to have a ram horn manifold either, something like a nice InlinePRO log manifold you can find for a couple hundred bucks used and i've seen plenty of them on cars that make over 500whp, granted they aren't as "good" as a quality ram horn, but it'll get the job done.
Also you can save some money by not going with Hondata. Hondata is awesome but with a small budget and as strict as 4k, save the money and go with Crome software on a p28, it may cost you in the neighborhood of $150 to find a p28 and have it chipped.
Begley
Oct 25, 2012 11:21 AM
LilTeggy2011
Mar 3, 2010 09:39 AM
dets93teg
Feb 14, 2007 12:17 PM
beedoublejay
Oct 27, 2002 08:35 PM
