Am I detonating or mis-firing?
Old Sep 29, 2010 | 05:04 PM
Romo Pyro's Avatar
Default Am I detonating or mis-firing?
How can I tell? There's DEFINITELY something going on.
The car "shudders" so-to-speak under any load at any rpm. Doesn't matter.
Info: b18c1 11.8:1cr. Tuned-ish. (ran just fine for a while. This is recent)
Research shows that if it is det. I should be hearing a "pinging" noise. And I don't. I'm at school right mow and won't be able to pull the plugs till tmro. But I'm FREAKING OUT. Someone help me, gimme some ideas. What should I try, what should I look for??
Old Sep 29, 2010 | 10:30 PM
95skunkedgsr's Avatar
Default Re: Am I detonating or mis-firing?
what is all done to the car ... and what dose "tuned-ish" mean ?
Old Sep 29, 2010 | 11:09 PM
Romo Pyro's Avatar
Usdm gsr with jdm itr pistons and a bunch of boltons.
The car was tuned a while ago, but mods have been done since, so afr and timing may be slightly off. In fact, I'm sure they are.
Old Sep 30, 2010 | 12:44 PM
did you do anything to the car befor it started shuddering or just out of no where , check for a vacum leak. dose the car rev up fine in nuetral or with the clutch in ?
Old Sep 30, 2010 | 01:06 PM
DDTECH's Avatar
Pull your plugs after a wide open throttle pull.. see if there's spics that look like black pepper or red pepper sprinkled on ur plugs..in the porclin area.
normally you'll know if your knocking if you put your car in 3rd gear, and at like 1500rpms mash the gas.. you hear some metal on metal noise which would indicate you are knocking / pinging.. you wont noticed in the higher rpms.. but its noiceable in the lower rpm range
Old Sep 30, 2010 | 02:51 PM
Romo Pyro's Avatar
You're right about it being more noticeable at lower rpms, but it doesn't sound like (as someone once put it) "bb's". It's just a series of "Thuds".
Old Sep 30, 2010 | 02:52 PM
Romo Pyro's Avatar
I'm gonna try and video tape it.
Old Sep 30, 2010 | 08:07 PM
a "thud" is more of a rod knock or you could of forgotten your thrustwashers
HaTa
Mar 27, 2006 03:22 PM
ATS*Mark
Dec 15, 2003 10:59 PM
mattcalica
Dec 8, 2003 08:08 PM
ITS BONE STOCK I SWEAR
Jun 22, 2001 04:26 AM
