BWR Rear Subframe and OEM rear sway.
Old Sep 29, 2010 | 04:35 PM
JDM Like Whoa's Avatar
Default BWR Rear Subframe and OEM rear sway.
I have a 98 GSR and recently purchased a BWR rear subframe brace. I am having trouble with the OEM rear sway working with the brace, almost like the holes for the sway were drilled incorrectly or something. Anyone else by chance have this issue? Or if you have successfully used this combo, please chime in or even better yet... post some pics. Thanks.
Old Sep 29, 2010 | 04:41 PM
VVENOM800TT's Avatar
Default Re: BWR Rear Subframe and OEM rear sway.
BWR sucks, get an ASM or a Function 7 brace. From what i've heard BWR has shitty quality parts and shitty costume service, look in the suspension forum and you'll see a thread there about their coilovers.
Old Sep 29, 2010 | 04:45 PM
It has already been purchased and removed from packaging.. Looking for a fix for it.
Old Sep 29, 2010 | 04:49 PM
Well then i'm not any help am i, i hope you get it fixed.
Old Sep 29, 2010 | 04:53 PM
Thanks, me too.
Old Sep 29, 2010 | 05:00 PM
dapek's Avatar
Re-tap the existing holes on the brace and use a new, correct sized bolt for the new tapped hole.
Old Sep 29, 2010 | 06:20 PM
I am going to try and modify the sway bracket before I modify the subframe brace.. bracket is probably a little cheaper if something went wrong.
Old Jan 30, 2011 | 03:47 PM
Racer_Chick's Avatar
Hey, I see you have successfully installed the BWR, nice pics on the other thread, btw!
But how did you do it? I encountered the same problem with my BWR, I have a 96 RS with its OEM sway bar. I think I made a huge mistake cutting down the D bracket bushings looking to squeeze them closer together. Obviously it didn't work. The car is on jack stands because I am stuck and it will stay there till I find new bushings. I looked up if thinner smaller brackets exist for my sway bar and nothing... please heeeeeeelp!!
Old Jan 30, 2011 | 05:06 PM
98lscoupe's Avatar
My asr brace was the same way the brackets for the d brackets would not line up with the stock sway bar, with just the d brackets the holes on the brace were too far away and with the extra extender thingy that went on below the d bracket the holes were too close together on the asr brace. Im just buying the asr 24mm sway I was planning on doing that eventually anyway. For now I would just go without the sway bar
Old Jan 30, 2011 | 06:44 PM
BlueIntegraBoy's Avatar
The subframe braces were not meant to fit with an OEM 14mm sway bar, hence the reason the d-brackets are not fitting.
Old Jan 31, 2011 | 07:56 AM
The curious thing about it is that the holes on the brace are actually closer together than the ones on the D Bracket, which seems to need an even smaller sway bar?
Makes NO sense!!
Anyways, suggestions?
Old Jan 31, 2011 | 08:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Why would you use a subframe brace with a stock sway bar? Stock sway bars don't need any additional bracing.
Old Mar 6, 2011 | 03:32 PM
FWIW, I got the OEM to fit.. Although now that it's spring time and there isn't salt and **** all over the place, I am putting on my ASR rear sway.
With the OEM rear sway.
rickscrx
Dec 19, 2011 05:08 AM
JDM Like Whoa
Suspension & Brakes
Sep 29, 2010 05:25 PM
super jdm yo
Jun 2, 2009 05:31 PM
bmoua
Sep 25, 2007 10:22 AM
RAK
Sep 24, 2005 07:34 PM
