oem rear sway setup help...
i'm picking up a oem em1 13mm rear sway setup and i wanted to know if the em1 mounting bracket works with the gsr 14mm rear sway bar? The brackets i'm talking about are the brackets which which hold the sway bar to the chassis(rear subframe). I checked the part numbers and the gsr and em1 brackets are different. I know the 94-99 integra LS/RS uses the same bracket as the gsr, so wouldn't the em1 rear sway bolt up?
here is a link to the gsr parts...part # 12 and 13
http://www.acuraoemparts.com/d...ch=no
link to em1 parts...part # 30
http://bkhondaparts.com/billka...dIrno=
you will need the 13mm bushing, the d brackets should work as long as the holes line up. the bracket should be fine as well, the only problem would be if the outer diameter of the bushing is to small or big for the si d brackets
hope this makes sense
gl
gl
Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">you will need the 13mm bushing, the d brackets should work as long as the holes line up. the bracket should be fine as well, the only problem would be if the outer diameter of the bushing is to small or big for the si d brackets
gl </TD></TR></TABLE>
well i have the gsr bushings and d brackets, my question is will the gsr d brackets bolt up to the em1 bracket stabilizer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">the gsr bushings are 14mm, and your using a 13mm bar. maybe I am misunderstanding you </TD></TR></TABLE>
haha sorry bro, basically i'm using everything off of a gsr. what i need to know is if the gsr setup bolts up to the em1 bracket stabilizer (bracket which holds the sway bar to the chassis)
