miller 110 handy mig not penetrating 1/8" Why?
Old Sep 29, 2010 | 01:20 PM
uberEFtuner's Avatar
Default miller 110 handy mig not penetrating 1/8" Why?
I have a miller 110 handy mig with gas. My question is why don't my weld hold. I,m welding 1/8" from home depot to my stock seat rails. It seems like when the wire feed is set to the correct settings its slows down when I weld and sputters. When I speed up the feed it lays a fat bead, but its not penetrating the seat rail metal. The seat slider rails seem to be less than
1/8" thick metal. I,m using a 13/2 gauge 20' extension cord, its probably a bad idea.
Old Sep 29, 2010 | 03:22 PM
CRX Si69's Avatar
Default Re: miller 110 handy mig not penetrating 1/8" Why?
if you can try plugging in directly to the wall. with oh so many feet of extension cord you lose amps. did you clean the seat rail with a grinder or wire brush?
Old Sep 29, 2010 | 07:30 PM
E-Rok's Avatar
EPIC TUNING
what are your volts at? are you pushing or pulling?
Old Sep 30, 2010 | 06:57 PM
91jdmhatchback's Avatar
Are you preping the material? You should have a bevel on that thick of material.
Old Sep 30, 2010 | 07:14 PM
highroller54's Avatar
what gas?
Old Oct 1, 2010 | 09:44 AM
blaze_125's Avatar
As said above, I'd start by ditching the extension cord.
Old Oct 1, 2010 | 07:27 PM
ninjaturtleEG's Avatar
turn up the volts lol
Old Oct 13, 2010 | 06:00 PM
Desir Performance's Avatar
I had the same problem before, and it turned out the my welder needed to be pluged into a dedicated line. The outlet that I was using had to many loads on it, so I ran a 10/2 line with a 40amp breaker and used it only for the welder.
Old Oct 13, 2010 | 10:22 PM
xtremescouts's Avatar
from an electricians stand point, 40 amps on a 10 guage extension cord is a bad idea. When we wire homes the 40 amp circuits are atleast a 8 guage wire.
From another point of view, no 110 volt mig welder needs more than 30 amps of power max. My brothers snap on muscle mig 140 which is a 100% duty cycle(yes 100%) 110 volt welder only needs 30 amps.
A little miller should only need a 20 amp cicuit. I run my lincold weldpak 3200 on a 15 fot 12 guage cord on a dedicated 20 amp circuit and have no problems. Ive done numerous back to back welds and have no issues with weld penetration or any other issues. My welds come out nice and clean and strong. The racks i built for my brothers work hang off the side of their trucks and they hit another truck with it while in theyre yard(he works for a wrecking yard) and it didnt even phase it so i know the welds are fine.
sorry for the babble but just saying my experiences.
I think he needs to bevel a little bit, turn the power up back the speed down just a little bit and play with it from there. Try all of this on a scrap peice and not on the seat rails that way none of your welds on the seat turn out weak.
If you cant get it to weld right, chances are that your technique might be wrong or the welder itself has issues. At thatpoint i would take them to someone else to get them welded as they are a safety item and need to be strong.
hope this helped and sorry for the long reply
Old Oct 14, 2010 | 09:00 AM
swappedcx's Avatar
If it was set up for flux, and your using gas...did you reverse the polarity? My hobart came setup for flux and wouldn't penetrate for ****...I forgot to switch it. Once I did, she does the job.
Old Oct 14, 2010 | 10:18 AM
dc2_dude's Avatar
turn up the volts. make sure you work surface is clean from oil/paint etc. and what wire are you running? are you running solid mig wire, or flux core wire. also dont run an extension cord. thats fail. unless its no longer then 10 feet long
Old Oct 24, 2010 | 09:01 AM
MR.johnson's Avatar
what size wire?
Old Oct 25, 2010 | 06:11 PM
NotAJDMFanBoy's Avatar
make sure it's all nice and clean. Check your wire tension. If it's loose it won't push correctly. Is there a rats nest of wire?
What size wire? Smaller wire may work better with a smaller machine. You may have to turn the wire speed down or voltage up
Old Oct 26, 2010 | 09:08 PM
Hey thanks for all the help. I,m using .30 wire. I think my nozzle is dirty and the arc is jumping to the slag on the nozzle. I need to play with some scraps. Thanks
Outrun
May 7, 2016 10:10 AM
shoklid
Jan 11, 2010 07:54 AM
Zhu962
Welding / Fabrication
Sep 26, 2008 12:46 PM
Momolove
Apr 9, 2008 10:30 PM
thatasiankidtony
Dec 4, 2006 09:25 PM
