97 Civic EX brake lights won't work - cut wires under dash
ive check the wires back to the lights and the grounds and the fuses.these 4 wires were cut when i took out my dash and have no pug for them, i also dont believe this is the stock switch is it?
Uploaded with ImageShack.us
BTW:
From what I can see (by scrolling lol) it looks like the plug for the brake light switch. Are the wires under the dash close to the brake pedal assembly, and is that open switch you posted screwed into the brake pedal mounting bracket?
If you hope to get help, then you must provide all relevant information about your car and engine:
https://honda-tech.com/forums/showpo...48&postcount=2
Please read the Stickies up top.
Sorry, 97 civic ex manual , yes the wires were right infront of the switch , I dunno how to downsize but if u click the photo it will link it to the right size, All other lights work
correct the white green goes the fusebox under the hood ,however i followed the green white and it goes to this white plug with a blue insert and is tapped up ??????? what does that plug do? so this mean no wire is going to my brakes?
also does anyone have the pin diagrams for both under the hood and dash fuse boxes and plugs connected to them?
^That's probably junction connector C442. At that point, the Grn/White wire from the brake switch branches into multiple Grn/Wht wires, one of which runs to the brake lights.
Check whether all four Grn/Wht wires at C442 have battery voltage to body ground only when the brake pedal is depressed.
if im holding this correctly it seems that there are wires not even pinned if this is c442 that is
i found a plug taped in the harness and it fits and the light work, but when the brake lights come on the side markers and parking lights do as well, the previous owner must of done a real hack job
green white white green wires, i made a jumper from the cream colored wire to the brake switch and the green wire and the brake lights work again with the parking lights
no i cant get the brake lights to work with out the parking lots to come on as well. also does c442 look like its missing wires to the pins?
I think C442 may be fine if you don't see any cut or loose wires.
Does the bulb number of the installed bulbs match what is recommended at the link below?
http://www.sylvania.com/ConsumerProd...RG-Results.htm
billa48
Dec 15, 2007 11:04 AM
