Good setup for street? Looking for 300-350whp.
Hey All,
94 DB8 w/ 98 ITR Swap, motor has 135K in good condition.
I am looking for a stock-ish looking setup (yes in CA) to support 300-350WHP+, make power up top still (I have been in a few cars with the greddy kit and I dont like how the power falls beyond 7K).
Now I understand I will have to get bottom end work to support the boost properly but just looking to shop for turbo parts right now.
Car will retain A/C (I have a baby)
Help me choose a manifold/ic/turbo combo!
Thanks.
Thanks.
-Mini Ram, 3" dp and exhaust
-T3/T04e 50 trim .63ar
-720cc injectors
-Comp Stg 3 (or 4) clutch
-GM3bar Map sensor
-2.5" IC Piping
Its not that terribly difficult to piece together the rest from here. Those parts will make your goal without going overboard on price OR going overboard on power capability.
-720cc injectors
-GM3bar Map sensor
-2.5" IC Piping
http://www.speedfactoryracing.net/st...roducts_id=100
EDIT:
I just read ShangaiOC's post. It didn't cross my mind that you want to hide the ramhorn because of CARB issues. How do you expect to hide the turbo, waste gate, blow-off valve, intercooler, ect? Simple answer, you can't.
Garrett 57 trim turbo
Spoolin Performance Log manifold package
Tial 38mm wg
440cc injectors
255lph fuel pump
stage 3 clutch
other little misc, but that will get you there
Tial 38mm wg
440cc injectors
255lph fuel pump
stage 3 clutch
Hide the reamhorn? Not sure I'm following. You can always swap for mini-ram.
EDIT:
EDIT:
So far the log manifold's position the wastegate right up in your face, the mini-ram manifold's are non-a/c
DSM manifold heat shield are quite large to cover the manifold / turbo. outter edge of IC painted black a long with IC Piping, stock airbox/arm will be modified to route IC piping through it w/ BOV inside. I'm more worried about where the wastegate will be located.
A turbo engine bay is a beautiful thing, its a shame to hide it.
http://www.speedfactoryracing.net/wp...r/100_1671.JPG
It really sucks you have to go through that much effort in California.
A turbo engine bay is a beautiful thing, it's not something that should have to hide.
You can forget welding a C.A.R.B. plate from Greddy to that. No cop in their right might would fall for it....
Find a family member in a modified friendly state and re-register the car and your license. You won't pass that in CA. Believe that.
do what everyone else does in california....find a dirty smog shop pay the $300 bucks and dont get your butt pulled over doing something stupid.
