H22 Build
I got a bone stock h22 I am currently running 7psi safely, how much would it cost be to build it with lower compression pisions ect. to handle more boost safely? An approximate number would be good Thanks.
Send it off to laskey or golden eagle.
Will run you about $3000 for a complete short block.
Then you need to factor in the cost of replacing things like HG, some ARP head studs, timing belt, water pump, manual tensioner conversion, and so on....
It will cost you about $4000 if you did the labour yourself.
honda_12V
Nov 2, 2013 04:19 AM
