lower control arm and rotor contact...wtfrick...
Old Sep 27, 2010 | 02:02 PM
rick_rabies's Avatar
I'm not Rick!
Default ball joint and rotor contact...wtfrick...
ok. so i have all oem gsr brakes/knuckles.
sum how. especialy when i turn to the right it grinds real bad.
the front control arm that holds the ball joint touchs and grinds the rotor.
i have no idea how this is happening.
i have all stock suspesion jus 2 inch lowering springs and 15" steelies.
i however have a broken weel stud...still how can this happen?
the wheel bearing is fun. it has no play in it. all the bushings are fine. all new bushings in.
in theory with the wheel assembly going up from a bump it would com away from the rotor correct?
any suggestions? i have no idea
Old Sep 27, 2010 | 03:19 PM
TunerN00b's Avatar
Default Re: lower control arm and rotor contact...wtfrick...
Try reading through here and see if any reasons / solutions are mentioned.
https://honda-tech.com/forums/suspension-brakes-54/lower-ball-joint-hitting-rotor-2836651/
Old Sep 27, 2010 | 03:49 PM
I'm not Rick!
wow very weird thanx, il read through it now
Old Sep 27, 2010 | 04:44 PM
jdmer329's Avatar
i believe its from camber being all the way positive cause the lower ball joint to bend in and hit the rotor. Just my theory.
Old Sep 27, 2010 | 04:49 PM
I'm not Rick!
ok i read the threads. this is very weird.
everything is completey stock except the 2" lowering springs..
and everything has been fine for the past 3 years.. til now...all of a sudden its this way.
balljoints/wheel bearings are new and have no play.
this isnt when im bouncing over bumps. this is jus cruising its rubbing
it started today. and it worsens when i turn right....idk..this sux.
also the wheel "looks" like it is at 0 degree camber. its not tilted in any direction
Old Sep 27, 2010 | 05:10 PM
jdmer329's Avatar
is all the suspension components torqued to specs? When was your last alignment?
Old Sep 28, 2010 | 04:23 AM
EHondaJDM's Avatar
If it happened all of a sudden do you remember hitting any hard bumps
right before it started?
Old Sep 28, 2010 | 04:47 AM
I'm not Rick!
no, no hard bumps. it was jus all of a sudden down the road.
if you didnt read the link and the other threads...the problem is
that stop tech brakes gave out rotor that were to thick and touched the ball joint
but i have oem rotors.
others say use a 3mm spacer behind the rotor...why. on oem brakes? thats absurd.
sum replaced the ball joint and that helpd a tiny bit cuz it was stiffer.
sum used bump stops. nothing
sum got stiffer springs...kinda helpd.
others got adjustcable UCAs and that helped...but im already at 0* camber
also oem wheels. im guessing the ball joint is junk from hitting bumps. idk.
there still hasnt been a solid solution.
also axle LENGTH...if it was a tadd longer...i bet it would fix the problem. but..how do you get longer then oem axles ? :O
Old Sep 28, 2010 | 05:24 AM
EHondaJDM's Avatar
yea but I don't get how you've bee driving all this time and all of a sudden you need a long axle, im willin to bet that lower bj has some play or your tie rod, only one side doing it?
Old Sep 28, 2010 | 05:47 AM
I'm not Rick!
both sides. jus psgnr side is alot worse.
either way.
ima get new parts on....agian
Old Sep 28, 2010 | 07:12 AM
EHondaJDM's Avatar
Double post sorry
Old Oct 25, 2010 | 11:01 AM
I'm not Rick!
SO THE CONCLUSION IS...............
i had the knuckle off and in my lap i took the rotor and put it on the knuckle and there is contact when you push the ball joint over...not normal.
so i got the karcepts hubs and new wheel bearings and ball joints..
new ball joints fixed it. it seems as thoug the actual ball and pin in the ball joint came out alittle or was bent.
Old Oct 25, 2010 | 03:41 PM
EHondaJDM's Avatar
Figured that was it
Prob should replace the other side before it ends up the same
Old Oct 26, 2010 | 05:14 AM
I'm not Rick!
werd. i did both sides at once since i had to get karcepts 36mm hubs
Old Oct 26, 2010 | 05:39 AM
EHondaJDM's Avatar
How much them thing run you.
You gotta buy em individually or they come in a set?
Old Oct 26, 2010 | 07:09 AM
I'm not Rick!
a set $295. 36mm but keep the 4lug setup, they come with ARP extended studs
http://cgi.ebay.com/ebaymotors/Karce...Q5fAccessories
Old Oct 28, 2010 | 04:17 PM
EHondaJDM's Avatar
Good buy!
r_kage
Aug 30, 2016 01:35 PM
kenzo42
Sep 2, 2013 10:17 PM
globy123
Aug 10, 2013 09:55 AM
spectastic
Honda Civic (2001 - 2005)
Feb 22, 2013 09:44 AM
avio
Apr 14, 2010 07:50 PM
