Tranny Problems
Old Sep 19, 2002 | 08:25 AM
fluffy's Avatar
Default Tranny/Check Engine Problems
I have a 93 civic with a jdm b16 swap. i was driving today, and it was extremely hard to shift. i had to push/pull it in to gear. and it stutters sometimes in gear as well. then, when i was a block from home, it wouldn't go into gear at all. i had to coast for a while, then pull real hard into 4th. any ideas what the problem is? clutch? i was pumping the clutch in the driveway when i finally got home, and it feels quite soft. there's plenty of fluid. could it be a pressure plate problem? tranny is shot? it does grind quite often in 3rd and 4th. i got the motor from hondamotors about 2 weeks ago. any thoughts would be greatly appreciated!
Regarding the check engine, it comes on after a while of driving, maybe at a certain temp... we checked the code - 23 - which reads a knock sensor. would old gas throw it? my car has been sitting since may until a week ago when we swapped it. what else would throw that code???
[Modified by fluffycivic, 1:52 PM 9/19/2002]
[Modified by fluffycivic, 2:02 PM 9/19/2002]
Old Sep 19, 2002 | 09:41 AM
fluffy's Avatar
Default Re: Tranny Problems (fluffycivic)
help!!
Old Sep 19, 2002 | 10:03 AM
fluffy's Avatar
aGaiN!!!
Old Sep 19, 2002 | 10:33 AM
fluffy's Avatar
Old Sep 19, 2002 | 10:54 AM
StyleTEG's Avatar
Sounds like what I am running into.
From what I have read its a bad release bearing. Does your clutch make a "clank" type sound when you are in nuteral and let it out?
From what I gather, the bad bearing is causing the clutch to not be fully disengaged which is why it studders and its hard to get into gear.
Old Sep 19, 2002 | 11:15 AM
fluffy's Avatar
Default Re: Tranny Problems (StyleTEG)
sort of, but i've kind of had this problem before with a d-series motor. ended up being the main shaft in the tranny, but that's not what mine is like this time. it just shifts REALLY hard, and sometimes doesn't want to go into gear at all. but the release bearing definitely sounds like it could be a problem. i think i'm gonna order an exedy in a minute... thanks. anyways, if anyone else maybe thinks it's something else, let me know!
Old Sep 19, 2002 | 12:41 PM
fluffy's Avatar
clutch is ordered, let's hope that helps! any ideas on the check engine light?
Old Sep 19, 2002 | 04:08 PM
mechanik's Avatar
No clue man.
Old Sep 19, 2002 | 06:28 PM
fluffy's Avatar
Default Re: Tranny Problems (mechanik)
thanks for your help sac
Old Sep 19, 2002 | 07:19 PM
hoya_10fintec's Avatar
i got code 23 a few days ago... it threw the code everytime when my engine was warmed up... when i actually checked the knock sensor, it wasn't connected.. the actual MOTOR pulled it out rocking back and forth real bad... check the knock sensor connection... if everything seems OK, then try replacing it...
u might wanna put the ignition timing back to normal, too, if advanced too much...
Old Sep 19, 2002 | 07:30 PM
fluffy's Avatar
Default Re: Tranny Problems (hoya_10fintec)
thank you thank you thank you! that's the **** i'm talking about. i'll put in work tomorrow to find out. thanks again
Old Sep 19, 2002 | 07:36 PM
no prob.
Old Sep 19, 2002 | 08:35 PM
Pengo's Avatar
does the clutch pedal still come up or is it like falling down more and more?
Old Sep 19, 2002 | 09:59 PM
fluffy's Avatar
Default Re: Tranny Problems (Pengo)
no, it still comes up, it just feels really sh!tty. like theres really nothing there, but it does keep coming up
Old Sep 20, 2002 | 08:09 PM
3rdGteg's Avatar
Yeah for the ks code, just check the connection at the sensor and the ecu end; it's prolly just a bad connection. Good luck on fixing your probs.
shuiyuan
Nov 14, 2012 04:42 PM
ek_b16
Dec 10, 2006 10:19 PM
JDMTegraR
Jul 26, 2005 05:24 AM
DA9teg93
Jun 12, 2005 04:09 AM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
