Problem starting
Old Sep 27, 2010 | 09:21 AM
nicknack25's Avatar
Default Problem starting
I have a 90 crx dx and sometimes when i try starting my car, all i hear is the starter clicking. i can hear the fuel lines go on as well. Finally swapped a b18a1 in my car and i have the same exact problem.. I keep turning the key and i hear the starter and fuel lines but nothing. Sometimes i hold the key on and then it starts. Is this an ignition problem?
Old Sep 27, 2010 | 09:28 AM
hatchet_honda's Avatar
Default Re: Problem starting
you can hear the fuel lines? what do they say?
Old Sep 27, 2010 | 09:31 AM
nicknack25's Avatar
they say eat ****
Old Sep 27, 2010 | 09:35 AM
sounds like maybe the clutch switch..if you have one on the 90 rex. my 91 si had a bad switch and it wouldnt do nothin but click once
Old Sep 27, 2010 | 09:43 AM
nicknack25's Avatar
Are you talking about the one thats on top of the clutch pedal?
Old Sep 27, 2010 | 10:29 AM
yes. since you swapped to a b series, which means a diff starter, so the starter itself cant be the prob. hows your tranny ground wire? so you have to keep turning the key for it to start?
Old Sep 27, 2010 | 10:31 AM
nicknack25's Avatar
Tranny ground wire is good. And yes i have to keep on turning the key for it to start. Sometimes it starts up with no problems even when its cold. I'll try swapping the clutch switch.
Black R
Apr 8, 2023 07:14 AM
gRim06
13
Oct 18, 2007 10:14 PM
Tad
Feb 7, 2006 03:35 PM
nikkon
Mar 14, 2005 12:05 AM
cincispeedemon
Sep 30, 2004 05:55 PM
