Transmission & Drivetrain Gearboxes, Differentials, Clutches
4 speed to 5 speed
Old Sep 27, 2010 | 09:11 AM
slowsinglecam's Avatar
Default 4 speed to 5 speed
My friend just picked up a 1990 EF Civic Hatch. It has a d16y8 swapped with a 4 speed trans. Its grinds into 3. So I have a trans at my house that we can swap that is a 5 speed. My question is what is needed to go from 4 to a 5 speed?
Old Sep 27, 2010 | 01:36 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: 4 speed to 5 speed
about 2 hours.....
Old Sep 27, 2010 | 02:21 PM
John The G's Avatar
im about to do the same swap in my 91 hatch. neone no if there are seals or gaskets that you have to buy to switch trannys.
Old Sep 28, 2010 | 07:58 AM
Originally Posted by Mista Bone
about 2 hours.....
So it bolts right in?????
Old Sep 28, 2010 | 03:21 PM
91tegraRS's Avatar
direct swap
remove 4 speed
install 5 speed
done
Old Sep 28, 2010 | 04:52 PM
MonkeyMagic's Avatar
everything drops out and bolts in.
may have some axle seal swapping to do depending on what trans/axle/seal combo you have going on.
(seals as per axle obviously. but trans may have XXX seal and car has YYY axle)
any rate.. if trans fluid (5w30) leaks when you put it together.. pull the seals out of the old trans and put them in the 5spd.
Old Sep 28, 2010 | 06:58 PM
Mista Bone's Avatar
D Tranny Guru
D-Series inner axles seals EXCEPT DOHC ZC are all the same.
Use 10w30 motor oil, 2 quarts.
Old Oct 1, 2010 | 09:48 AM
NotoriousCRV's Avatar
WHat year is the 5 speed tranny out of. I ran into the problem where I had an 88 tranny and needed the clutch and flywheel to make it fit in my 91 hatch. 88=20 splines you will need the clutch and fly wheel to make it work
89=21 splines " " " " " "
90-91=22 splines
Old Oct 1, 2010 | 05:16 PM
94EG8's Avatar
Seagull Management
90-91=22 splines
See this handy chart for figuring out which clutch you need:
Old Oct 3, 2010 | 02:09 PM
John The G's Avatar
what about a 94 onto a 88 engine
Old Oct 3, 2010 | 02:32 PM
94EG8's Avatar
Seagull Management
'90 - '00 pressure plate, disc and flywheel. '92 - '00 throwout/release bearing.
Old Oct 4, 2010 | 04:02 PM
John The G's Avatar
thanx man i appreciate all the info
colonelcorto
Mar 2, 2019 07:39 AM
civicbizz253
Aug 30, 2017 04:22 AM
90efdvr
Mar 12, 2014 05:42 AM
DenzComp
May 15, 2007 08:00 AM
